跳转到主内容
加入维修社区 - 创建账户
How to Rip a Seam
你所需要的
  1. How to Rip a Seam, How to Rip a Seam: 步骤 1 中的图像 1,2 How to Rip a Seam, How to Rip a Seam: 步骤 1 中的图像 2,2
    • Slip the sharp end of the seam ripper through a single stitch in the seam you want to remove.
    • Be sure your seam ripper goes through only the stitch, not the fabric, or you could puncture/tear the fabric.
    询问修复机器人
    添加评论
    • Slide the seam ripper forward, bringing the stitch into the crux of the seam ripper's fork and onto the blade.
    • Gently push the seam ripper forward, cutting the thread.
    • Rely on the blade to do the work. Do not apply a lot of force, as the seam ripper can slip and puncture the fabric.
    询问修复机器人
    添加评论
  2. How to Rip a Seam: 步骤 3 中的图像 1,1
    • You can use the method described in steps 1 and 2 to completely rip any seam. However, if you have a seam that binds two pieces of fabric, it is easier to rip the seam using the method described in step 4, below.
    • In order to use the method in Step 4, you need to remove the first few stitches of the seam using the method we already described in Step 1. Removing these stitches enables you to separate the two pieces of fabric and use the seam ripper on the stitches that hold them together.
    • Using the method below also helps prevent accidental puncturing of the garment.
    询问修复机器人
    添加评论
  3. How to Rip a Seam: 步骤 4 中的图像 1,2 How to Rip a Seam: 步骤 4 中的图像 2,2
    • Separate the two pieces of fabric held together by your seam.
    • Bring the sharp end of the seam ripper between the two pieces of fabric.
    • Slip the sharp end of the seam ripper beneath one of the stitches. Be careful to avoid catching the fabric.
    询问修复机器人
    添加评论
    • Slide the seam ripper forward. Bring the thread into the crux of the fork and onto the blade.
    • Gently push the seam ripper forward again, cutting the thread.
    • Continue working, stitch by stitch, until the seam has been removed. Take your time, being careful not to damage the fabric.
    • Remove all of the loose threads from the ripped seam to prevent tangling when you resew the seam.
    询问修复机器人
    添加评论
终点
取消:我没有完成这个指南。
6等其他人完成本指南。
Brittany McCrigler
于03/05/12注册
90,988 声望
创作了142篇指南
团队
iFixit iFixit 的会员
Staff
123 名成员
创作了32,260篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 27
过去 30 天: 144
总计 27,706
