当前版本的文档还未经巡查,您可以查看最新的已查核版本。
这个步骤还没有翻译 帮忙翻译一下
Before disassembling your Atari Lynx, be sure the device is powered off.
Remove any game in the console by opening the right latch and sliding the game to the right.
Remove the four 35 mm Phillips #1 screws at each corner of the backside on the Atari Lynx.
Pinch the rear panel with your fingers and lift away from the Atari.
Remove the battery panel by pinching the sides with your fingers and lifting it away from the Atari.
Be sure not to tear any wires attached to battery panel.
Remove the control panel by pinching the sides with your fingers and lifting it away from the Atari.
Be sure not to tear the speaker wire while removing the control panel.
Desolder the four aluminum tabs and for more information on soldering click here.
Remove the aluminum back protector to gain access to the C10 capacitor.
Desolder the C10 capacitor.
取消:我没有完成这个指南。
另外一个人完成了本指南。
与4其他贡献者
于01/27/14注册
443 声望
创作了4篇指南
徽章: 9
+ 6更多徽章
CPSU-MANESS-W14S1G42
5 名成员
创作了16篇指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
过去 24 小时: 0
过去 7 天: 15
过去 30 天: 36
总计 4,880
