跳转到主内容
Replacing Atari Lynx Speaker
你所需要的
  1. Replacing Atari Lynx Speaker, Atari Lynx: 步骤 1 中的图像 1,1
    • Before disassembling your Atari Lynx, be sure the device is powered off.
    • Remove any game in the console by opening the right latch and sliding the game to the right.
  2. Replacing Atari Lynx Speaker: 步骤 2 中的图像 1,1
    • Remove the four 35 mm Phillips #1 screws at each corner of the backside on the Atari Lynx.
    • Pinch the rear panel with your fingers and lift away from the Atari.
  3. Replacing Atari Lynx Speaker: 步骤 3 中的图像 1,1
    • Remove the battery panel by pinching the sides with your fingers and lifting it away from the Atari.
    • Be sure not to tear any wires attached to battery panel.
  4. Replacing Atari Lynx Speaker: 步骤 4 中的图像 1,1
    • Remove the control panel by pinching the sides with your fingers and lifting it away from the Atari.
    • Be sure not to tear the speaker wire while removing the control panel.
  5. Replacing Atari Lynx Speaker, Speaker: 步骤 5 中的图像 1,2 Replacing Atari Lynx Speaker, Speaker: 步骤 5 中的图像 2,2
    • Remove the logic board from the console.
    • Flip the logic board so the screen is facing down.
  6. Replacing Atari Lynx Speaker: 步骤 6 中的图像 1,2 Replacing Atari Lynx Speaker: 步骤 6 中的图像 2,2
    • Now you will need to desolder both of the wires connected to the speaker.
    • If you are having trouble desoldering, click here.
    • Finally solder the new speaker back on and follow the previous steps in reverse order.
结论
4等其他人完成本指南。
Tyler Williams
于01/26/14注册
333 声望
创作了2篇指南
团队
Cal Poly, Team 1-42, Maness Winter 2014 Cal Poly, Team 1-42, Maness Winter 2014 的会员
CPSU-MANESS-W14S1G42
5 名成员
创作了16篇指南
2条评论
Does anyone know the screw sizes for the lynx 2 console please
RBKing 80 - 回复
What are the specs on the speaker? Size? Wattage?
gregory draudt - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 19
总计 1,448
