简介
Do you want to change your hard disk to increase its capacity or replace it, because it no longer works? Perfect, you've come to the right place, this tutorial is for you!
你所需要的
Pop the center cover open on the bottom cover.
Remove the center screw with a #00 Phillips screwdriver.
Use a T5 Torx screwdriver for the remaining screws around the edge of the bottom cover.
Remove the screw with a #00 Phillips screwdriver.
Remove the hard disk from its location.
To reassemble your device, follow the instructions in reverse order.
2等其他人完成本指南。
由衷感谢以下译者:
100%
Schwarzer正在帮助我们修复这个世界! 您也想加入吗?
开始翻译 ›
