简介
Your WiFi card no longer works and you want to change it. You've come to the right place, this tutorial is for you.
你所需要的
Pop the center cover open on the bottom cover.
Remove the center screw with a #00 Phillips screwdriver.
Use a T5 Torx screwdriver for the remaining screws around the edge of the bottom cover.
Disconnect the two wires from the WiFi card. You can do this with a pair of pliers or your fingernail.
Remove the screw with a #00 Phillips screwdriver.
Now remove your WiFi card to replace it.
To reassemble your device, follow the instructions in reverse order.
另外一个人完成了本指南。
由衷感谢以下译者:
100%
Schwarzer正在帮助我们修复这个世界! 您也想加入吗?
开始翻译 ›
