跳转到主内容
Repairing an FJ-3LED Globe Electric Push Light
你所需要的
  1. Repairing an FJ-3LED Globe Electric Push Light, Repairing an FJ-3LED Globe Electric Push Light: 步骤 1 中的图像 1,3 Repairing an FJ-3LED Globe Electric Push Light, Repairing an FJ-3LED Globe Electric Push Light: 步骤 1 中的图像 2,3 Repairing an FJ-3LED Globe Electric Push Light, Repairing an FJ-3LED Globe Electric Push Light: 步骤 1 中的图像 3,3
    • Lift the black lid off of the battery slot and remove the batteries.
  2. Repairing an FJ-3LED Globe Electric Push Light: 步骤 2 中的图像 1,3 Repairing an FJ-3LED Globe Electric Push Light: 步骤 2 中的图像 2,3 Repairing an FJ-3LED Globe Electric Push Light: 步骤 2 中的图像 3,3
    • Use the Phillips #1 screwdriver to remove four 1.4 mm screws from the back of the light.
    • Take the black part out and separate it from the white case.
  3. Repairing an FJ-3LED Globe Electric Push Light: 步骤 3 中的图像 1,1
    • Identify which part of the lamp is broken.
    • in this case, one of the connections in the circuit had been disconnected.
  4. Repairing an FJ-3LED Globe Electric Push Light: 步骤 4 中的图像 1,1
    • For tips on Soldering, see How to Solder and Desolder Connections.
    • Attach the disconnected wire to its joint using solder and iron tip. Place the tip of the soldering iron against the solder pad.
    • Melt enough solder onto the solder pad.
    • Remove both the solder and the soldering iron tip from the connection as soon as enough solder melts onto the pad.
    • Don't forget to use gloves.
  5. Repairing an FJ-3LED Globe Electric Push Light: 步骤 5 中的图像 1,2 Repairing an FJ-3LED Globe Electric Push Light: 步骤 5 中的图像 2,2
    • Push the circuit into its place.
    • Click the button to see if the wires are connected .
  6. Repairing an FJ-3LED Globe Electric Push Light: 步骤 6 中的图像 1,2 Repairing an FJ-3LED Globe Electric Push Light: 步骤 6 中的图像 2,2
    • If the lights turn on, the connection is perfect in the circuit and the disconnected joint is now connected.
    • Place the white case on top of the circuit and close it with the Phillips #1 screwdriver.
结论
Rojina Saberi
于05/11/21注册
133 声望
撰写一个指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 11
总计 366
