跳转到主内容
Repairing 1984-1989 Toyota 4Runner Idler Arm
你所需要的
  1. Repairing 1984-1989 Toyota 4Runner Idler Arm, Repairing 1984-1989 Toyota 4Runner Idler Arm: 步骤 1 中的图像 1,1
    • First the Idler arm must be removed from the truck. Another guide has instructions to take the arm off.
  2. Repairing 1984-1989 Toyota 4Runner Idler Arm: 步骤 2 中的图像 1,2 Repairing 1984-1989 Toyota 4Runner Idler Arm: 步骤 2 中的图像 2,2
    • Place the arm in a vise.
    • Spray the cap with penetrating lubricant.
    • Using a screw driver, tap the idler arm bracket cap off.
    • If it will not come off easily, then check out the trouble shooting page.
  3. Repairing 1984-1989 Toyota 4Runner Idler Arm: 步骤 3 中的图像 1,3 Repairing 1984-1989 Toyota 4Runner Idler Arm: 步骤 3 中的图像 2,3 Repairing 1984-1989 Toyota 4Runner Idler Arm: 步骤 3 中的图像 3,3
    • Using a 19 mm socket, take the nut off from inside the idler arm bracket.
    • If the arm rotates in the bracket, then it can be taken out of the vice and placed on the ground.
    • Once on the ground, your foot can be used to stop the arm from rotating and enable you to put torque on the nut.
    • Once the nut is off, the arm can be gently tapped out of the bracket.
  4. Repairing 1984-1989 Toyota 4Runner Idler Arm: 步骤 4 中的图像 1,2 Repairing 1984-1989 Toyota 4Runner Idler Arm: 步骤 4 中的图像 2,2
    • Remove the oil seal.
    • Remove the plastic bushings with a flat head.
    • Both bushings and oil seals should be removed and replaced.
    • Fill the bracket with MP grease and then put the arm back into the bracket.
    • Wipe off any grease that squeezes out of the bracket.
结论
Colton Baker
于10/20/15注册
328 声望
创作了2篇指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 5
总计 675
