本指南有最近更改,您可查看未经巡查的最新版本。
简介
We will unscrew the bottom faceplate, then remove the base to access the internal components.
你所需要的
Using a Phillips #00 screw driver, remove the four 6.86 mm screws from the metal plate.
Release the tabs on each side of the module by simultaneously pushing each tab away from the RAM.
Remove the RAM module from the iMac.
即将完成!
结论
9等其他人完成本指南。
