当前版本的文档还未经巡查,您可以查看最新的已查核版本。
Place the computer monitor face down on a safe, harmless surface.
Using a Phillips #00 screw driver, remove the four 6.86 mm screws from the metal plate.
Release the tabs on each side of the module by simultaneously pushing each tab away from the RAM.
These tabs lock the module in place and releasing them will cause the module to "pop" up.
Remove the RAM module from the iMac.
Open the base by carefully pulling straight off, do not rotate the cover.
Open slowly to ensure that no cables are damaged or disconnected.
Squeeze the small black tab and wiggle gently to remove the colored power cable.
Do not pull directly on the colored wires.
Do not remove black grounding wire.
嵌入本指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
预览
