跳转到主内容
Razer Megalodon – Virtual 7.1 Surround Sound USB Gaming Headset Microphone Boom Replacement
你所需要的
  1. Razer Megalodon – Virtual 7.1 Surround Sound USB Gaming Headset Microphone Boom Replacement, Microphone Boom: 步骤 1 中的图像 1,1
    • Remove the left ear cushion by rotating it counterclockwise as far as possible.
    • Pull the cushion upwards to remove it from the device.
  2. Razer Megalodon – Virtual 7.1 Surround Sound USB Gaming Headset Microphone Boom Replacement: 步骤 2 中的图像 1,3 Razer Megalodon – Virtual 7.1 Surround Sound USB Gaming Headset Microphone Boom Replacement: 步骤 2 中的图像 2,3 Razer Megalodon – Virtual 7.1 Surround Sound USB Gaming Headset Microphone Boom Replacement: 步骤 2 中的图像 3,3
    • Remove the six 6 mm screws around the speaker housing.
    • Although it is only possible to reassemble this piece one way, you can save yourself some trouble by making a mark that lines up the speaker housing with the ear cup.
  3. Razer Megalodon – Virtual 7.1 Surround Sound USB Gaming Headset Microphone Boom Replacement: 步骤 3 中的图像 1,1
    • Remove the three 6 mm screws on the inside of the ear cup.
  4. Razer Megalodon – Virtual 7.1 Surround Sound USB Gaming Headset Microphone Boom Replacement: 步骤 4 中的图像 1,2 Razer Megalodon – Virtual 7.1 Surround Sound USB Gaming Headset Microphone Boom Replacement: 步骤 4 中的图像 2,2
    • There are two wires going into the boom. One powers the LED lights and the other goes to the microphone. Each wire has two smaller ones in them.
    • Cut both wires, strip the shielding, solder the new wires together, and wrap them in electrical tape or use heat shrink. Be sure to insulate the wires from each other.
    • The two sets of wires are different colors, so you can figure out which wire powers the LEDs and which goes to the microphone.
结论
另外一个人完成了本指南。
团队
Michigan Tech, Team 5-8, Lauer Spring 2014 Michigan Tech, Team 5-8, Lauer Spring 2014 的会员
MTU-LAUER-S14S5G8
3 名成员
创作了13篇指南
3条评论
Ok, so where does one get a replacement boom mic?
stolensoulz79 - 回复
My classmate saw a pair of headphones on a
website today. He thought it was nice looking and good price. He asked me my
opinion. What do you think? Here is the link:
kobe - 回复
opinion. What do you think? Here is the link: http://menghu.ebcoo.net/product/original...
kobe - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 18
总计 2,731
