跳转到主内容
Razer Deathadder Essential RZ01-0254 Mouse Buttons Replacement
你所需要的
  1. Razer Deathadder Essential RZ01-0254 Mouse Buttons Replacement, Mouse Buttons: 步骤 1 中的图像 1,2 Razer Deathadder Essential RZ01-0254 Mouse Buttons Replacement, Mouse Buttons: 步骤 1 中的图像 2,2
    • Use a spudger or opening tool to remove the top skates from the mouse.
    • Poke a hole in the middle of the bar code to expose the 3 screws holding the mouse together.
  2. Razer Deathadder Essential RZ01-0254 Mouse Buttons Replacement: 步骤 2 中的图像 1,1
    • Use a Phillips #1 screwdriver to remove the three 9 mm screws that are holding the mouse together.
  3. Razer Deathadder Essential RZ01-0254 Mouse Buttons Replacement: 步骤 3 中的图像 1,3 Razer Deathadder Essential RZ01-0254 Mouse Buttons Replacement: 步骤 3 中的图像 2,3 Razer Deathadder Essential RZ01-0254 Mouse Buttons Replacement: 步骤 3 中的图像 3,3
    • Open the mouse, and use the Phillips #1 screwdriver remove the two 11 mm screws that are located on the left side of the motherboard.
    • Also, remove the single 4 mm screw next to the mouse wheel using the Phillips #1 screwdriver.
    • After you remove all three screws the motherboard should be free.
  4. Razer Deathadder Essential RZ01-0254 Mouse Buttons Replacement: 步骤 4 中的图像 1,2 Razer Deathadder Essential RZ01-0254 Mouse Buttons Replacement: 步骤 4 中的图像 2,2
    • This is the component that we will be replacing and its 3 contact points.
  5. Razer Deathadder Essential RZ01-0254 Mouse Buttons Replacement: 步骤 5 中的图像 1,1
    在这个步骤中使用的工具:
    Desoldering Pump
    $3.99
    • Using your soldering iron and desoldering pump, desolder the 3 contact points that attach to each button as marked.
    • Be careful when using a soldering iron, as it can burn you if not used correctly.
  6. Razer Deathadder Essential RZ01-0254 Mouse Buttons Replacement: 步骤 6 中的图像 1,3 Razer Deathadder Essential RZ01-0254 Mouse Buttons Replacement: 步骤 6 中的图像 2,3 Razer Deathadder Essential RZ01-0254 Mouse Buttons Replacement: 步骤 6 中的图像 3,3
    • Remove the button that you just desoldered.
    • Then solder the new button back into place. Repeat for both buttons.
  7. Razer Deathadder Essential RZ01-0254 Mouse Buttons Replacement: 步骤 7 中的图像 1,3 Razer Deathadder Essential RZ01-0254 Mouse Buttons Replacement: 步骤 7 中的图像 2,3 Razer Deathadder Essential RZ01-0254 Mouse Buttons Replacement: 步骤 7 中的图像 3,3
    • Return the motherboard to its original position, and replace the two 11 mm screws and the single 4 mm screw using a Phillips #1 screwdriver.
  8. Razer Deathadder Essential RZ01-0254 Mouse Buttons Replacement: 步骤 8 中的图像 1,1
    • Close up the mouse, and replace the three 9 mm using a Phillips #1 screwdriver.
  9. Razer Deathadder Essential RZ01-0254 Mouse Buttons Replacement: 步骤 9 中的图像 1,1
    • Finally, replace the skates and you are finished.
终点
6等其他人完成本指南。
JMason
于09/30/21注册
349 声望
撰写一个指南
4指南评论
My scroll wheel was totally messed up, when I would scroll in down, it would randomly scroll up for for a split second, and vice versa. This guide was super helpful in figuring out how to take apart the mouse and clean out the scroll wheel sensor, which turned out to have a ton of cat hair wrapped around the axle.
Chris Etler - 回复
My mouse is not working when i plug it in the pc what is the problem ?
Kros Sss - 回复
Thank you for the help! Had a Sharkoon Fireglider mouse and apart from a few other different placement designs was able to replace the left click button component. Much appreciated!
Yashin lalji - 回复
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 59
过去 30 天: 283
总计 11,960
