跳转到主内容
Razer Blade RZ09-0130 2015 Wi-Fi Card Replacement
你所需要的
  1. Razer Blade RZ09-0130 2015 Wi-Fi Card Replacement, Back Panel: 步骤 1 中的图像 1,2 Razer Blade RZ09-0130 2015 Wi-Fi Card Replacement, Back Panel: 步骤 1 中的图像 2,2
    • Be sure to power off the device before beginning.
    • Use a Torx T5 screwdriver to remove the ten 3 mm screws along the edge of the back panel.
  2. Razer Blade RZ09-0130 2015 Wi-Fi Card Replacement: 步骤 2 中的图像 1,2 Razer Blade RZ09-0130 2015 Wi-Fi Card Replacement: 步骤 2 中的图像 2,2
    • Remove the back panel from the laptop by sliding it away from the hinge.
    • This device is missing the battery. Make sure to detach the battery connector before proceeding with laptop repairs.
  3. Razer Blade RZ09-0130 2015 Wi-Fi Card Replacement, Wi-Fi Card: 步骤 3 中的图像 1,2 Razer Blade RZ09-0130 2015 Wi-Fi Card Replacement, Wi-Fi Card: 步骤 3 中的图像 2,2
    • Flip up the black plastic lock-bar on the ZIF connector, then gently pull the ribbon cable directly out of its motherboard port.
  4. Razer Blade RZ09-0130 2015 Wi-Fi Card Replacement: 步骤 4 中的图像 1,2 Razer Blade RZ09-0130 2015 Wi-Fi Card Replacement: 步骤 4 中的图像 2,2
    • Use a Phillips #0 screwdriver to remove the single 3 mm screw from the upper-right corner of the Wi-Fi card.
  5. Razer Blade RZ09-0130 2015 Wi-Fi Card Replacement: 步骤 5 中的图像 1,2 Razer Blade RZ09-0130 2015 Wi-Fi Card Replacement: 步骤 5 中的图像 2,2
    • Slide an ESD-safe tool under the black and gray coaxial cable connections, and gently lift the plugs vertically to disconnect them from the Wi-Fi card.
    • Grip the Wi-Fi card from both sides and pull it directly out of its port.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 9
过去 7 天: 15
过去 30 天: 35
总计 341
