跳转到主内容
Razer Blade Pro 17 2019 Battery Replacement
你所需要的
  1. Razer Blade Pro 17 2019 Battery Replacement, Battery: 步骤 1 中的图像 1,2 Razer Blade Pro 17 2019 Battery Replacement, Battery: 步骤 1 中的图像 2,2
    • Unplug the laptop.
    • Press and hold the power button to shut down the laptop.
  2. Razer Blade Pro 17 2019 Battery Replacement: 步骤 2 中的图像 1,3 Razer Blade Pro 17 2019 Battery Replacement: 步骤 2 中的图像 2,3 Razer Blade Pro 17 2019 Battery Replacement: 步骤 2 中的图像 3,3
    • Remove the 12 screws that secure the lower case with a T5 Torx screwdriver.
  3. Razer Blade Pro 17 2019 Battery Replacement: 步骤 3 中的图像 1,3 Razer Blade Pro 17 2019 Battery Replacement: 步骤 3 中的图像 2,3 Razer Blade Pro 17 2019 Battery Replacement: 步骤 3 中的图像 3,3
    • Insert the opening picks into the gap between the back plate and the body of the laptop and pry around the perimeter until the lower case releases.
    • It is easier to use the gap at the ethernet port.
    • Lift up and remove the lower case.
    • Be careful not to place anything on the back to avoid scratching any components.
  4. Razer Blade Pro 17 2019 Battery Replacement: 步骤 4 中的图像 1,3 Razer Blade Pro 17 2019 Battery Replacement: 步骤 4 中的图像 2,3 Razer Blade Pro 17 2019 Battery Replacement: 步骤 4 中的图像 3,3
    • Remove the black sticker on the fan assembly.
  5. Razer Blade Pro 17 2019 Battery Replacement: 步骤 5 中的图像 1,2 Razer Blade Pro 17 2019 Battery Replacement: 步骤 5 中的图像 2,2
    • Use your fingernails to gently "walk" the battery connector directly out of its port.
    • Do not pull directly on the wires, as depicted in the photo.
  6. Razer Blade Pro 17 2019 Battery Replacement: 步骤 6 中的图像 1,2 Razer Blade Pro 17 2019 Battery Replacement: 步骤 6 中的图像 2,2
    • Use your fingernails or a spudger to gently lever the fan connector directly out of its socket.
    • Do not pull directly on the wires, as show in the photos.
  7. Razer Blade Pro 17 2019 Battery Replacement: 步骤 7 中的图像 1,3 Razer Blade Pro 17 2019 Battery Replacement: 步骤 7 中的图像 2,3 Razer Blade Pro 17 2019 Battery Replacement: 步骤 7 中的图像 3,3
    • Use a Phillips #1 screwdriver to remove the 10 screws that secure the battery and fan assembly.
  8. Razer Blade Pro 17 2019 Battery Replacement: 步骤 8 中的图像 1,3 Razer Blade Pro 17 2019 Battery Replacement: 步骤 8 中的图像 2,3 Razer Blade Pro 17 2019 Battery Replacement: 步骤 8 中的图像 3,3
    • Lift the fan assembly and battery out of the chassis.
结论
For optimal performance, calibrate your newly installed battery after completing this guide.
Nate
于04/15/24注册
157 声望
撰写一个指南
团队
UC Davis, Team 2-3, Morris Spring 2024 UC Davis, Team 2-3, Morris Spring 2024 的会员
UCD-MORRIS-S24S2G3
3 名成员
创作了1篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 9
过去 30 天: 30
总计 66
