跳转到主内容
Razer Blade 15" (2019) SSD Replacement
你所需要的
  1. Razer Blade 15" (2019) SSD Replacement, Prepare your laptop for disassembly: 步骤 1 中的图像 1,2 Razer Blade 15" (2019) SSD Replacement, Prepare your laptop for disassembly: 步骤 1 中的图像 2,2
    • Allow your laptop's battery to drain below 25% before starting this repair—a charged battery may catch fire if damaged.
    • Unplug all cables, fully shut down your laptop, and close the lid.
  2. Razer Blade 15" (2019) SSD Replacement, Unfasten the back cover: 步骤 2 中的图像 1,1
    • Rotate your laptop so the screen hinge is farthest from you.
    • Use a Torx T5 driver to remove the ten 3.8 mm-long screws securing the back cover.
  3. Razer Blade 15" (2019) SSD Replacement, Insert an opening pick: 步骤 3 中的图像 1,3 Razer Blade 15" (2019) SSD Replacement, Insert an opening pick: 步骤 3 中的图像 2,3 Razer Blade 15" (2019) SSD Replacement, Insert an opening pick: 步骤 3 中的图像 3,3
    • Depending on the age and condition of your laptop, the back cover may come off sooner than this guide instructs. If the cover feels loose, remove it at any time.
    • Apply a suction handle to the right edge of the back cover, between the middle screws and the screws closest to you.
    • Pull up on the suction handle to create a small gap between the back cover and the frame.
    • Insert an opening pick into the gap.
  4. Razer Blade 15" (2019) SSD Replacement, Angle the opening pick: 步骤 4 中的图像 1,3 Razer Blade 15" (2019) SSD Replacement, Angle the opening pick: 步骤 4 中的图像 2,3 Razer Blade 15" (2019) SSD Replacement, Angle the opening pick: 步骤 4 中的图像 3,3
    • Angle your opening pick upward, away from the frame. Keep it angled upward as long as it's between the back cover and the frame.
    • Insert your pick up to 10 mm (0.4 in) deep.
  5. Razer Blade 15" (2019) SSD Replacement, Free the bottom right corner: 步骤 5 中的图像 1,3 Razer Blade 15" (2019) SSD Replacement, Free the bottom right corner: 步骤 5 中的图像 2,3 Razer Blade 15" (2019) SSD Replacement, Free the bottom right corner: 步骤 5 中的图像 3,3
    • Slide your opening pick around the bottom right corner of the back cover to free it from the frame.
  6. Razer Blade 15" (2019) SSD Replacement, Free the front edge: 步骤 6 中的图像 1,3 Razer Blade 15" (2019) SSD Replacement, Free the front edge: 步骤 6 中的图像 2,3 Razer Blade 15" (2019) SSD Replacement, Free the front edge: 步骤 6 中的图像 3,3
    • Slide your opening pick along the front edge and around the front left corner of the back cover to free it from the frame.
  7. Razer Blade 15" (2019) SSD Replacement, Remove the back cover: 步骤 7 中的图像 1,3 Razer Blade 15" (2019) SSD Replacement, Remove the back cover: 步骤 7 中的图像 2,3 Razer Blade 15" (2019) SSD Replacement, Remove the back cover: 步骤 7 中的图像 3,3
    • Remove the back cover.
    • Lay the back cover down on its rubber feet to avoid damaging the gray thermal pads on its underside.
  8. Razer Blade 15" (2019) SSD Replacement, Soften the battery cable tape adhesive: 步骤 8 中的图像 1,2 Razer Blade 15" (2019) SSD Replacement, Soften the battery cable tape adhesive: 步骤 8 中的图像 2,2
    • Apply a heated iOpener to the battery cable tape for one minute.
    • You can also use a hair dryer—but be careful, as overheating the battery may damage it or create a fire hazard.
  9. Razer Blade 15" (2019) SSD Replacement, Peel up the battery cable tape: 步骤 9 中的图像 1,3 Razer Blade 15" (2019) SSD Replacement, Peel up the battery cable tape: 步骤 9 中的图像 2,3 Razer Blade 15" (2019) SSD Replacement, Peel up the battery cable tape: 步骤 9 中的图像 3,3
    在这个步骤中使用的工具:
    购买
    • Be careful not to damage the battery with your tool.
    • Use blunt nose tweezers or your fingers to peel the battery cable tape away from the cable.
  10. Razer Blade 15" (2019) SSD Replacement, Disconnect the battery: 步骤 10 中的图像 1,3 Razer Blade 15" (2019) SSD Replacement, Disconnect the battery: 步骤 10 中的图像 2,3 Razer Blade 15" (2019) SSD Replacement, Disconnect the battery: 步骤 10 中的图像 3,3
    • Use the point of a spudger to press on alternating sides of the battery connector and walk it out of its socket.
  11. Razer Blade 15" (2019) SSD Replacement, Unfasten the SSD: 步骤 11 中的图像 1,2 Razer Blade 15" (2019) SSD Replacement, Unfasten the SSD: 步骤 11 中的图像 2,2
    • Use a Phillips screwdriver to remove the 3 mm screw securing the SSD.
    • The SSD will pop up slightly.
  12. Razer Blade 15" (2019) SSD Replacement, Remove the SSD: 步骤 12 中的图像 1,3 Razer Blade 15" (2019) SSD Replacement, Remove the SSD: 步骤 12 中的图像 2,3 Razer Blade 15" (2019) SSD Replacement, Remove the SSD: 步骤 12 中的图像 3,3
    • Pull the SSD straight out of its socket and remove it.
结论
另外一个人完成了本指南。
Clay Eickemeyer
于09/19/22注册
67,399 声望
创作了453篇指南
团队
iFixit iFixit 的会员
Staff
136 名成员
创作了17,430篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 5
过去 7 天: 14
过去 30 天: 86
总计 1,030
