简介
Use this guide to remove or replace the left fan in your Razer Blade 15" (2019).
Note: This guide refers to the "left" fan as the one on your left-hand side when the screen is open and facing you.
你所需要的
Unplug all cables, fully shut down your laptop, and close the lid.
Rotate your laptop so the screen hinge is farthest from you.
Use a Torx T5 driver to remove the ten 3.8 mm-long screws securing the back cover.
Apply a suction handle to the right edge of the back cover, between the middle screws and the screws closest to you.
Pull up on the suction handle to create a small gap between the back cover and the frame.
Insert an opening pick into the gap.
Angle your opening pick upward, away from the frame. Keep it angled upward as long as it's between the back cover and the frame.
Insert your pick up to 10 mm (0.4 in) deep.
Slide your opening pick around the bottom right corner of the back cover to free it from the frame.
Slide your opening pick along the front edge and around the front left corner of the back cover to free it from the frame.
Remove the back cover.
Lay the back cover down on its rubber feet to avoid damaging the gray thermal pads on its underside.
Apply a heated iOpener to the battery cable tape for one minute.
Use blunt nose tweezers or your fingers to peel the battery cable tape away from the cable.
Use the point of a spudger to press on alternating sides of the battery connector and walk it out of its socket.
The antenna cables look very similar. Label one of them with a piece of tape or marker. Do the same to its socket on the Wi-Fi card.
Insert one arm of angled tweezers under the metal neck of each antenna cable and pry up to disconnect it.
Use tweezers or your fingers to move the antenna cables to the left, away from the charging connector.
Use your spudger to push on alternating sides of the charging port connector to "walk" it out of its socket.
Use your fingers to grab the rubber sleeve around the left fan cable and pull the connector straight out of its socket.
Use a Phillips screwdriver to remove the two 6.7 mm screws securing the left fan.
Lift the left side of the fan.
Use tweezers or your fingers to guide the antenna and screen cables out from the tabs on the left fan.
Remove the fan.
