跳转到主内容
加入维修社区 - 创建账户
Razer Blade 15" (2018) Back Cover Replacement
你所需要的
  1. Razer Blade 15" (2018) Back Cover Replacement, Unfasten the back cover: 步骤 1 中的图像 1,1
    • Rotate your laptop so the screen hinge is farthest from you.
    • Use a Torx T5 driver to remove the ten 3.8 mm-long screws securing the back cover.
  2. Razer Blade 15" (2018) Back Cover Replacement, Insert an opening pick: 步骤 2 中的图像 1,3 Razer Blade 15" (2018) Back Cover Replacement, Insert an opening pick: 步骤 2 中的图像 2,3 Razer Blade 15" (2018) Back Cover Replacement, Insert an opening pick: 步骤 2 中的图像 3,3
    • Depending on the age and condition of your laptop, the back cover may come off sooner than this guide instructs. If the cover feels loose, remove it at any time.
    • Apply a suction handle to the right edge of the back cover, between the middle screws and the screws closest to you.
    • Pull up on the suction handle to create a small gap between the back cover and the frame.
    • Insert an opening pick into the gap.
  3. Razer Blade 15" (2018) Back Cover Replacement, Angle the opening pick: 步骤 3 中的图像 1,3 Razer Blade 15" (2018) Back Cover Replacement, Angle the opening pick: 步骤 3 中的图像 2,3 Razer Blade 15" (2018) Back Cover Replacement, Angle the opening pick: 步骤 3 中的图像 3,3
    • Angle your opening pick upward, away from the frame. Keep it angled upward as long as it's between the back cover and the frame.
    • Insert your pick up to 10 mm (0.4 in) deep.
  4. Razer Blade 15" (2018) Back Cover Replacement, Free the bottom right corner: 步骤 4 中的图像 1,3 Razer Blade 15" (2018) Back Cover Replacement, Free the bottom right corner: 步骤 4 中的图像 2,3 Razer Blade 15" (2018) Back Cover Replacement, Free the bottom right corner: 步骤 4 中的图像 3,3
    • Slide your opening pick around the bottom right corner of the back cover to free it from the frame.
  5. Razer Blade 15" (2018) Back Cover Replacement, Free the front edge: 步骤 5 中的图像 1,3 Razer Blade 15" (2018) Back Cover Replacement, Free the front edge: 步骤 5 中的图像 2,3 Razer Blade 15" (2018) Back Cover Replacement, Free the front edge: 步骤 5 中的图像 3,3
    • Slide your opening pick along the front edge and around the front left corner of the back cover to free it from the frame.
  6. Razer Blade 15" (2018) Back Cover Replacement, Remove the back cover: 步骤 6 中的图像 1,3 Razer Blade 15" (2018) Back Cover Replacement, Remove the back cover: 步骤 6 中的图像 2,3 Razer Blade 15" (2018) Back Cover Replacement, Remove the back cover: 步骤 6 中的图像 3,3
    • Remove the back cover.
    • Lay the back cover down on its rubber feet to avoid damaging the gray thermal pads on its underside.
结论
Clay Eickemeyer
于09/19/22注册
98,688 声望
创作了471篇指南
团队
Guide Team Guide Team 的会员
Staff
10 名成员
创作了16,279篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 20
总计 1,024
