跳转到主内容
Razer Blackwidow Chroma Key Switch Replacement
你所需要的
  1. Razer Blackwidow Chroma Key Switch Replacement, Rubber Feet: 步骤 1 中的图像 1,2 Razer Blackwidow Chroma Key Switch Replacement, Rubber Feet: 步骤 1 中的图像 2,2
    • Turn the keyboard over so that it is lying flat on its face.
    • Use the iFixit opening tool to pry the rubber feet off the keyboard.
  2. Razer Blackwidow Chroma Key Switch Replacement, Front Panel: 步骤 2 中的图像 1,2 Razer Blackwidow Chroma Key Switch Replacement, Front Panel: 步骤 2 中的图像 2,2
    • Use a Phillips #1 screwdriver to remove the six screws on the back of the keyboard.
    • Use an opening tool as a wedge between the front and back panel to pry open the front panel.
    • If the front and back panel won't separate, DO NOT use excessive force. This may result in damaging the keyboard.
    • Instead, slide the opening tool across the keyboard in between the front and back panel. Go around the edges of the keyboard until the panels disconnect.
    • Flip the keyboard over so the keys are facing up.
    • Grabbing the left and right lips of the front panel, lift both ends up, removing the front panel.
  3. Razer Blackwidow Chroma Key Switch Replacement, Back Panel: 步骤 3 中的图像 1,2 Razer Blackwidow Chroma Key Switch Replacement, Back Panel: 步骤 3 中的图像 2,2
    • Use a Philips #1 Screwdriver to remove the four screws located below the keys.
    • Lift the main circuit board and flip it over, placing it on its top.
    • Be cautious of the wire connected to the USB Port Board.
  4. Razer Blackwidow Chroma Key Switch Replacement, Key Switch: 步骤 4 中的图像 1,3 Razer Blackwidow Chroma Key Switch Replacement, Key Switch: 步骤 4 中的图像 2,3 Razer Blackwidow Chroma Key Switch Replacement, Key Switch: 步骤 4 中的图像 3,3
    • De-solder the anchor of each key that you desire to replace with a soldering iron.
    • For more information on soldering connections, please visit the How to Solder and Desolder Connections guide.
    • Remove the key switch once the de-soldering is complete.
结论
7等其他人完成本指南。
3条评论
hello where to buy the switches for this keyboard?
ninja636 - 回复
I've seen Razer Green Switches (the ones for the Blackwidow) with RGB lighting available for sale on eBay.
I hope that helps!
Matt Von Grimm -
Hi Annika, I have razer black widow chroma overwatch edition, Is gateron optical switch compatible with it?
Jaydeep Parmar - 回复
添加评论
浏览统计数据:
过去 24 小时: 14
过去 7 天: 94
过去 30 天: 365
总计 20,897
