简介
This guide will walk you through the process of replacing the top housing on your Razer BlackWidow V3 Pro.
你所需要的
Remove the keycaps using either a keycap puller or your hands
Repeat until all keycaps are off
Peel the lower-right rubber feet off just enough to reveal the 9mm Phillips screw.
Lift the top of the keyboard up and slightly to the front.
While pushing up, watch the LED on the front (circled red on the 2nd picture) and make sure it doesn't get damaged while removing the lid.
Flip up the black locking flap on the ZIF connector using a fingernail or a spudger, then carefully pull out the ribbon cable.
另外一个人完成了本指南。
2指南评论
Thanks for the screw location guide. I totally missed the one under the foot pad on the back. Also, thanks for warning me about the LED on the front part of the board. I actually came here to fix my jumpy volume jog dial. Once the top housing was successfully disassembled, the remaining steps to remove and clean the jog dial were a piece of cake. Great guide with clear descriptions and relevant photos. Thanks 👍🏾
Thanks for the feedback! I'm glad you were able to take the keyboard apart :).
op_ -
