跳转到主内容
RYDIS H68 Pro Side Brush Motor Replacement
你所需要的
  1. RYDIS H68 Pro Side Brush Motor Replacement, Battery: 步骤 1 中的图像 1,2 RYDIS H68 Pro Side Brush Motor Replacement, Battery: 步骤 1 中的图像 2,2
    • Flip the vacuum over so that the wheels are facing you.
    • Use a Phillips #1 screwdriver to remove the four 10 mm screws that surround the battery cover.
  2. RYDIS H68 Pro Side Brush Motor Replacement: 步骤 2 中的图像 1,1
    • Lift the battery cover up to reveal the battery.
    • Remove the battery.
  3. RYDIS H68 Pro Side Brush Motor Replacement, Bumper: 步骤 3 中的图像 1,3 RYDIS H68 Pro Side Brush Motor Replacement, Bumper: 步骤 3 中的图像 2,3 RYDIS H68 Pro Side Brush Motor Replacement, Bumper: 步骤 3 中的图像 3,3
    • Remove the eight 10 mm Phillips #1 screws.
  4. RYDIS H68 Pro Side Brush Motor Replacement: 步骤 4 中的图像 1,3 RYDIS H68 Pro Side Brush Motor Replacement: 步骤 4 中的图像 2,3 RYDIS H68 Pro Side Brush Motor Replacement: 步骤 4 中的图像 3,3
    • Hold the front bumper and pull it off.
    • It requires a lot of force to pull the bumper off.
  5. RYDIS H68 Pro Side Brush Motor Replacement: 步骤 5 中的图像 1,3 RYDIS H68 Pro Side Brush Motor Replacement: 步骤 5 中的图像 2,3 RYDIS H68 Pro Side Brush Motor Replacement: 步骤 5 中的图像 3,3
    • Pry off the back bumper by going around the entire top of the bumper with the metal spudger.
  6. RYDIS H68 Pro Side Brush Motor Replacement, Side Brush Motor: 步骤 6 中的图像 1,1
    • Begin by unscrewing the 2 10mm screws using a Phillips #1 screwdriver.
    • Unlatch the latches indicated. It can be easily done with your finger.
    • Once unsecured, the covering for the sensors can easily be removed allowing access to the sensors.
    • The reason for these first few steps is to avoid damaging the signal wires for the sensor.
  7. RYDIS H68 Pro Side Brush Motor Replacement: 步骤 7 中的图像 1,1
    • This step just shows you how everything looks after the previous steps were completed.
    • There are sensors on both the left and right side. This can be done for either side.
  8. RYDIS H68 Pro Side Brush Motor Replacement: 步骤 8 中的图像 1,1
    • Unscrew the five 10mm screws using a Phillips #1 screwdriver.
  9. RYDIS H68 Pro Side Brush Motor Replacement: 步骤 9 中的图像 1,1
    • The side brush motor can now be removed by lifting it up.
结论
另外一个人完成了本指南。
jude auguste
于02/15/17注册
108 声望
撰写一个指南
团队
USFT-Lacy-S17S005G2 USFT-Lacy-S17S005G2 的会员
Local Repair Groups
4 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 14
总计 596
