跳转到主内容
RIDGID R84015 X2 Disassembly
你所需要的
  1. RIDGID R84015 X2 Disassembly, RIDGID R84015 X2 Case Removal: 步骤 1 中的图像 1,2 RIDGID R84015 X2 Disassembly, RIDGID R84015 X2 Case Removal: 步骤 1 中的图像 2,2
    • Remove the backplate.
    • Using a Torx T20 screwdriver, remove the four screws attaching the back plate.
  2. RIDGID R84015 X2 Disassembly: 步骤 2 中的图像 1,1
    • Remove the drill handle.
    • Using the Phillips #2 screwdriver, remove the five screws attaching the drill handle to the body.
  3. RIDGID R84015 X2 Disassembly: 步骤 3 中的图像 1,2 RIDGID R84015 X2 Disassembly: 步骤 3 中的图像 2,2
    • Remove the gear casing from the body.
    • Using the Philips #2 screwdriver, remove the four screws attaching the gear casing to the body.
  4. RIDGID R84015 X2 Disassembly, RIDGID R84015 X2 Disassembly: 步骤 4 中的图像 1,1
    • With your drill taken apart, move your attention to the trigger and forward reverse switch.
  5. RIDGID R84015 X2 Disassembly: 步骤 5 中的图像 1,1
    • Check to see that the forward reverse switch isn't broken.
    • NOTE: small tab on trigger fits into groove on forward reverse switch
  6. RIDGID R84015 X2 Disassembly: 步骤 6 中的图像 1,1
    • With the battery attached, check that the wires work when the trigger is pulled.
    • Put multimeter wires here.
    • If wires work and drill doesn't, the problem is with the motor.
  7. RIDGID R84015 X2 Disassembly: 步骤 7 中的图像 1,1
    • Make sure plastic is not broken and switch is not stuck.
终点
2等其他人完成本指南。
Brian
于04/12/10注册
100 声望
撰写一个指南
团队
Cal Poly, Team 15-48, Garner Spring 2010 Cal Poly, Team 15-48, Garner Spring 2010 的会员
CPSU-GARNER-S10S15G48
6 名成员
创作了10篇指南
一条评论
I was able to diagnose and fix my problem with my black and decker following your instructions. TY
boxingchaos2011 - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 11
过去 30 天: 18
总计 13,778
