跳转到主内容
RCA RCT6272W23 Display Replacement
你所需要的
  1. RCA RCT6272W23 Display Replacement, Case: 步骤 1 中的图像 1,2 RCA RCT6272W23 Display Replacement, Case: 步骤 1 中的图像 2,2
    • Use a Phillips #00 screwdriver to remove both 4.1 mm screws at the top of the device which hold it together.
  2. RCA RCT6272W23 Display Replacement: 步骤 2 中的图像 1,2 RCA RCT6272W23 Display Replacement: 步骤 2 中的图像 2,2
    • Press the plastic opening tool into the space between the front and back portions of the case.
    • Run it along the perimeter of the device to unhook the plastic tabs.
    • Gently pull both sides apart.
    • The speaker is connected to the back cover, so be careful when separating.
  3. RCA RCT6272W23 Display Replacement, Motherboard: 步骤 3 中的图像 1,3 RCA RCT6272W23 Display Replacement, Motherboard: 步骤 3 中的图像 2,3 RCA RCT6272W23 Display Replacement, Motherboard: 步骤 3 中的图像 3,3
    • Use a soldering iron to remove the soldered connections on the motherboard
    • For your safety and to ensure a correct repair, be sure to exercise caution when using the soldering iron.
    • For more information about soldering, check out this guide.
  4. RCA RCT6272W23 Display Replacement: 步骤 4 中的图像 1,1
    • Use a philips #00 screwdriver to unscrew the three 4.064mm screws which attach the motherboard to the front of the device.
  5. RCA RCT6272W23 Display Replacement: 步骤 5 中的图像 1,2 RCA RCT6272W23 Display Replacement: 步骤 5 中的图像 2,2
    • Use your fingers to pop the three black tabs up to release the flat plastic data transfer cables.
  6. RCA RCT6272W23 Display Replacement: 步骤 6 中的图像 1,1
    • Pull up the motherboard from the rest of the body.
  7. RCA RCT6272W23 Display Replacement, Display: 步骤 7 中的图像 1,1
    • Using a plastic opening tool, pry the battery off of the rest of the body.
    • The battery is attached to the display with double sided tape. It may be best to have a new strip of double sided tape to reattach the battery.
  8. RCA RCT6272W23 Display Replacement: 步骤 8 中的图像 1,3 RCA RCT6272W23 Display Replacement: 步骤 8 中的图像 2,3 RCA RCT6272W23 Display Replacement: 步骤 8 中的图像 3,3
    • Using a spudger, separate the display surface from the front cover.
    • Be careful not to break the tabs that hold the display screen in place.
    • A second spudger may be necessary to help hold the position of the display screen.
结论
4等其他人完成本指南。
Ross Pennala
于03/19/15注册
214 声望
撰写一个指南
团队
Michigan Tech, Team 1-5, Lauer Spring 2015 Michigan Tech, Team 1-5, Lauer Spring 2015 的会员
MTU-LAUER-S15S1G5
2 名成员
创作了12篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 10
总计 2,423
