跳转到主内容
RCA Pro10 Edition Speaker Replacement
你所需要的
  1. RCA Pro10 Edition Speaker Replacement, Speaker: 步骤 1 中的图像 1,2 RCA Pro10 Edition Speaker Replacement, Speaker: 步骤 1 中的图像 2,2
    • Using a separating tool, look for a seam in the plastic casing that looks most accessible.
    • Use the prying tool to separate the front and back casing, working your way around the perimeter.
    • Utilize a card tool or a pick to assist in keeping the case separated.
    • To reassemble the device simply align the two casing halves and pinch to snap together or press down on the edges while the device in on a table.
  2. RCA Pro10 Edition Speaker Replacement: 步骤 2 中的图像 1,1
    • Flip over the back of the device while keeping it close to the front, the speaker is attached to it.
    • Remove the yellow tape securing the speaker to the back casing.
  3. RCA Pro10 Edition Speaker Replacement: 步骤 3 中的图像 1,2 RCA Pro10 Edition Speaker Replacement: 步骤 3 中的图像 2,2
    • Use the separating tool to pry the speaker from its surface.
    • Use caution when removing the speaker, you may damage the screen.
    • Cut or desolder the wires to replace or repair the speaker.
结论
Dayne Russell
于01/27/15注册
404 声望
创作了4篇指南
团队
Pasco Hernando, Team 1-1, Prince Winter 2015 Pasco Hernando, Team 1-1, Prince Winter 2015 的会员
PHSC-PRINCE-W15S1G1
6 名成员
创作了10篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 5
总计 859
