跳转到主内容
RCA Pro10 Edition Camera Replacement
你所需要的
  1. RCA Pro10 Edition Camera Replacement, Speaker: 步骤 1 中的图像 1,2 RCA Pro10 Edition Camera Replacement, Speaker: 步骤 1 中的图像 2,2
    • Using a separating tool, look for a seam in the plastic casing that looks most accessible.
    • Use the prying tool to separate the front and back casing, working your way around the perimeter.
    • Utilize a card tool or a pick to assist in keeping the case separated.
    • To reassemble the device simply align the two casing halves and pinch to snap together or press down on the edges while the device in on a table.
  2. RCA Pro10 Edition Camera Replacement: 步骤 2 中的图像 1,1
    • Flip over the back of the device while keeping it close to the front, the speaker is attached to it.
    • Remove the yellow tape securing the speaker to the back casing.
  3. RCA Pro10 Edition Camera Replacement: 步骤 3 中的图像 1,2 RCA Pro10 Edition Camera Replacement: 步骤 3 中的图像 2,2
    • Use the separating tool to pry the speaker from its surface.
    • Use caution when removing the speaker, you may damage the screen.
    • Cut or desolder the wires to replace or repair the speaker.
  4. RCA Pro10 Edition Camera Replacement, Camera: 步骤 4 中的图像 1,3 RCA Pro10 Edition Camera Replacement, Camera: 步骤 4 中的图像 2,3 RCA Pro10 Edition Camera Replacement, Camera: 步骤 4 中的图像 3,3
    • Using a P00 Phillips screwdriver, remove the three screws securing the black plastic camera housing and remove it.
    • Peel back the beige tape while holding down the camera ribbon cable to prevent tears
  5. RCA Pro10 Edition Camera Replacement: 步骤 5 中的图像 1,2 RCA Pro10 Edition Camera Replacement: 步骤 5 中的图像 2,2
    • Lift the locking tab that is securing the camera ribbon cable.
    • Slide the ribbon cable out from the connector and remove from casing.
结论
Dayne Russell
于01/27/15注册
404 声望
创作了4篇指南
团队
Pasco Hernando, Team 1-1, Prince Winter 2015 Pasco Hernando, Team 1-1, Prince Winter 2015 的会员
PHSC-PRINCE-W15S1G1
6 名成员
创作了10篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 8
总计 473
