跳转到主内容
Pyle Astro PTBL7C LCD Replacement
你所需要的
  1. Pyle Astro PTBL7C LCD Replacement, LCD: 步骤 1 中的图像 1,2 Pyle Astro PTBL7C LCD Replacement, LCD: 步骤 1 中的图像 2,2
    • Using the plastic opening tool, work your way along the edge of the tablet.
    • The display is held in place by plastic tabs which slide into recesses in the rear plastic panel.
    • Once all clips are released, gently open and separate the front display assembly and the rear plastic panel.
    • Place the front display assembly facing front side down to expose the inside.
  2. Pyle Astro PTBL7C LCD Replacement: 步骤 2 中的图像 1,2 Pyle Astro PTBL7C LCD Replacement: 步骤 2 中的图像 2,2
    • Remove the three 4 mm JIS #0 screws to release the PCB board.
  3. Pyle Astro PTBL7C LCD Replacement: 步骤 3 中的图像 1,1
    • The display is held in place by plastic tabs which slide over the outer edges of the backside of the display.
    • Gently work your way around the display while pulling the plastic tabs back to release the LCD display from the front panel.
  4. Pyle Astro PTBL7C LCD Replacement: 步骤 4 中的图像 1,1
    • Once all clips are released gently open and separate the front plastic display from the LCD and place the LCD face down.
    • The front plastic display contains the external touch panel, and the capacitive touch screen overlay.
  5. Pyle Astro PTBL7C LCD Replacement: 步骤 5 中的图像 1,1
    • Using both hands, gently release the ribbon cable to the capacitive touch screen overlay from the PCB board by pushing both gray tabs outwards.
  6. Pyle Astro PTBL7C LCD Replacement: 步骤 6 中的图像 1,1
  7. Pyle Astro PTBL7C LCD Replacement: 步骤 7 中的图像 1,1
    在这个步骤中使用的工具:
    Plastic Cards
    $2.99
    • Using a plastic card, gently remove the adhesive that holds the battery in place and separate the battery from the LCD panel.
    • Exercise extreme caution and be sure to not rupture the battery casing.
  8. Pyle Astro PTBL7C LCD Replacement: 步骤 8 中的图像 1,1
结论
Andrew Redifer
于03/27/18注册
265 声望
创作了2篇指南
团队
IUPUI, Team S3-G6, Harley Spring 2018 IUPUI, Team S3-G6, Harley Spring 2018 的会员
IUPUI-HARLEY-S18S3G6
3 名成员
创作了4篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 10
总计 412
