跳转到主内容
Prototyping a Board
  1. Prototyping a Board, Board layout using EAGLE: 步骤 1 中的图像 1,3 Prototyping a Board, Board layout using EAGLE: 步骤 1 中的图像 2,3 Prototyping a Board, Board layout using EAGLE: 步骤 1 中的图像 3,3
    • Create the board layout using EAGLE FREE on more information on this step.
    • A video tutorial for using EAGLE for a board layout can be found here.
    • Remove all the labels and export it as a monochrome image (.png).
  2. Prototyping a Board, Convert to .rml file: 步骤 2 中的图像 1,2 Prototyping a Board, Convert to .rml file: 步骤 2 中的图像 2,2
    • Upload the image to fabmodules.org.
    • Output format for "Roland mill (.rml)".
    • The process box is how thick you want the cuts. Select "PCP traces (1/64)".
  3. Prototyping a Board, Setting up the output: 步骤 3 中的图像 1,2 Prototyping a Board, Setting up the output: 步骤 3 中的图像 2,2
    • From the output menu, select the following: Machine: SRM-20, X0: 0, Y0: 0, X0: 0. Leave the rest as default.
    • Then select the "calculate" button.
    • Next select the "save" button.
    • The image shows the cut cut patterns. (The red lines are where the machine is picked up and moved to the next spot to cut.)
    • Repeat steps 2 and 3 but with the minor change of selecting "PCB outlines (1/32)" in the "process" option.
  4. Prototyping a Board, Starting the Roland SRM-20: 步骤 4 中的图像 1,2 Prototyping a Board, Starting the Roland SRM-20: 步骤 4 中的图像 2,2
    • Push the green button to turn on the Roland SRM-20 and plug the machine's USB into computer. Note: it must be a windows computer.
    • Open the program VPanel for SRM-20. You can download the program and manual here.
    • Hit the "on" button to run the machine for a minute to allow it to warm up.
  5. Prototyping a Board, Adding file to VPanel: 步骤 5 中的图像 1,3 Prototyping a Board, Adding file to VPanel: 步骤 5 中的图像 2,3 Prototyping a Board, Adding file to VPanel: 步骤 5 中的图像 3,3
    • Select the "cut" button which will bring up a new window.
    • Click the "add" button to add a file.
    • Add the file and click "open".
    • Then select the "output" button.
  6. Prototyping a Board, Setting up the Roland SRM-20: 步骤 6 中的图像 1,3 Prototyping a Board, Setting up the Roland SRM-20: 步骤 6 中的图像 2,3 Prototyping a Board, Setting up the Roland SRM-20: 步骤 6 中的图像 3,3
    • Set the bit and the material. And set the "home" for xy and for z. See the manual for these instructions.
    • Note: you will see this dialog box when you set the "home". Select "yes".
    • Note: there is a sacrificial board on top to protect the machine.
    • Once everything is ready, select the "output" button. This will begin cutting process.
    • Click here for a more detailed tutorial from an outside site.
终点
另外一个人完成了本指南。
Brooke Mason
于05/29/19注册
2,958 声望
创作了17篇指南
团队
Open-Storm Open-Storm 的会员
Community
14 名成员
创作了24篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 5
总计 208
