跳转到主内容
Protocol Videodrone AP Propeller Motors Replacement
你所需要的
  1. Protocol Videodrone AP Propeller Motors Replacement, Propeller Motors: 步骤 1 中的图像 1,1
    • Power off the drone before proceeding with the rest of the guide.
  2. Protocol Videodrone AP Propeller Motors Replacement: 步骤 2 中的图像 1,1
    • Use the Phillips #0 screwdriver to remove four propeller screws.
    • If you don't own the screwdriver included with the drone kit, use a Phillips #0 screwdriver.
  3. Protocol Videodrone AP Propeller Motors Replacement: 步骤 3 中的图像 1,2 Protocol Videodrone AP Propeller Motors Replacement: 步骤 3 中的图像 2,2
    • Use the Phillips #0 screwdriver to remove eight propeller guard screws.
  4. Protocol Videodrone AP Propeller Motors Replacement: 步骤 4 中的图像 1,2 Protocol Videodrone AP Propeller Motors Replacement: 步骤 4 中的图像 2,2
    • Use the Phillips #0 screwdriver to remove eight housing screws from the bottom of the drone.
  5. Protocol Videodrone AP Propeller Motors Replacement: 步骤 5 中的图像 1,1
    • Open up housing to reveal main circuit board.
  6. Protocol Videodrone AP Propeller Motors Replacement: 步骤 6 中的图像 1,2 Protocol Videodrone AP Propeller Motors Replacement: 步骤 6 中的图像 2,2
    • Use the Phillips #0 screwdriver to remove three motor housing screws. There are three screws per motor.
    • The plastic housing is glued directly to motor.
  7. Protocol Videodrone AP Propeller Motors Replacement: 步骤 7 中的图像 1,3 Protocol Videodrone AP Propeller Motors Replacement: 步骤 7 中的图像 2,3 Protocol Videodrone AP Propeller Motors Replacement: 步骤 7 中的图像 3,3
    • Desolder the wires connecting the propeller motor to the motherboard (2 per motor) and remove the motor from the device.
    • For more information on soldering connections, please visit the How to Solder and Desolder Connections guide.
结论
2等其他人完成本指南。
Karan Paranganat
于11/07/19注册
352 声望
创作了2篇指南
团队
IUPUI, Team S2-G2, Harley Fall 2019 IUPUI, Team S2-G2, Harley Fall 2019 的会员
IUPUI-HARLEY-F19S2G2
3 名成员
创作了2篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 275
