跳转到主内容
Protocol TerraCopter EVO Left & Right Joystick Replacement
你所需要的
  1. Protocol TerraCopter EVO Left & Right Joystick Replacement, Controller's battery: 步骤 1 中的图像 1,2 Protocol TerraCopter EVO Left & Right Joystick Replacement, Controller's battery: 步骤 1 中的图像 2,2
    • Using a Phillips #0 screwdriver, remove the screw connecting the battery cover to the controller.
    • Remove the battery cover from the controller.
  2. Protocol TerraCopter EVO Left & Right Joystick Replacement: 步骤 2 中的图像 1,1
    • Remove all of four of the AA batteries from the controller.
  3. 注意:步骤 3-4 源自标记为进行中的 指南
    Protocol TerraCopter EVO Left & Right Joystick Replacement, Protocol TerraCopter EVO Controller Opening: 步骤 3 中的图像 1,1
    • Note: the four Phillips screws on the rear panel are a millimeter longer than the two screws near the antenna and the two screws on the handle.
    • Orientate the controller to where the battery compartment is facing upwards.
    • Remove the four 5mm and four 4mm Phillips #1 screws from the case.
  4. Protocol TerraCopter EVO Left & Right Joystick Replacement: 步骤 4 中的图像 1,1
    • Since the battery wires are still attached, carefully move the rear panel down to expose the motherboard.
  5. Protocol TerraCopter EVO Left & Right Joystick Replacement, Left & Right Joystick: 步骤 5 中的图像 1,1
    • Remove the eight 5mm Phillips #1 screws from the motherboard.
  6. Protocol TerraCopter EVO Left & Right Joystick Replacement: 步骤 6 中的图像 1,2 Protocol TerraCopter EVO Left & Right Joystick Replacement: 步骤 6 中的图像 2,2
    • After removing the screws, orientate the motherboard to where the side with the black joysticks face upwards.
    • Pull the black plastic joysticks from the motherboard, out of their their assembly.
  7. Protocol TerraCopter EVO Left & Right Joystick Replacement: 步骤 7 中的图像 1,1
    • Once the joysticks are removed, orientate the motherboard to where the green side is facing upwards.
    • On the green side of the motherboard, locate the two sets of ten pin arrays that hold the joystick assembly to the motherboard.
  8. Protocol TerraCopter EVO Left & Right Joystick Replacement: 步骤 8 中的图像 1,1
    • Melt the existing solder points on the pin arrays with a soldering iron and lift the joystick assemblies from their location on the motherboard.
    • Check out our How to Solder and Desolder Connections guide if you are unfamiliar with soldering practices.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 6
总计 137
