跳转到主内容
Protocol TerraCopter EVO Controller Motherboard Replacement
你所需要的
  1. Protocol TerraCopter EVO Controller Motherboard Replacement, Controller's battery: 步骤 1 中的图像 1,2 Protocol TerraCopter EVO Controller Motherboard Replacement, Controller's battery: 步骤 1 中的图像 2,2
    • Using a Phillips #0 screwdriver, remove the screw connecting the battery cover to the controller.
    • Remove the battery cover from the controller.
  2. Protocol TerraCopter EVO Controller Motherboard Replacement: 步骤 2 中的图像 1,1
    • Remove all of four of the AA batteries from the controller.
  3. 注意:步骤 3-4 源自标记为进行中的 指南
    Protocol TerraCopter EVO Controller Motherboard Replacement, Protocol TerraCopter EVO Controller Opening: 步骤 3 中的图像 1,1
    • Note: the four Phillips screws on the rear panel are a millimeter longer than the two screws near the antenna and the two screws on the handle.
    • Orientate the controller to where the battery compartment is facing upwards.
    • Remove the four 5mm and four 4mm Phillips #1 screws from the case.
  4. Protocol TerraCopter EVO Controller Motherboard Replacement: 步骤 4 中的图像 1,1
    • Since the battery wires are still attached, carefully move the rear panel down to expose the motherboard.
  5. Protocol TerraCopter EVO Controller Motherboard Replacement, Controller Motherboard: 步骤 5 中的图像 1,1
    • Remove the eight 5mm Phillips #1 screws from the motherboard.
  6. Protocol TerraCopter EVO Controller Motherboard Replacement: 步骤 6 中的图像 1,1
    • Locate the set of four green wires and one black wire attached to the motherboard.
    • Remove the male, white connector by pressing up on the two tabs on the female connector. Then, pull the connector away from the female connector on the motherboard
  7. Protocol TerraCopter EVO Controller Motherboard Replacement: 步骤 7 中的图像 1,1
    • Locate the single pin holding the negative and positive wires to the motherboard. Each lead should have one pin holding each wire to the green side of the motherboard.
    • Using a soldering iron, melt the existing solder point for the red lead (positive line).
    • Using a soldering iron, melt the existing solder point for the black lead (negative line).
    • Pull the red and black leads through their respective holes, out of the motherboard.
    • Check out our How to Solder and Desolder Connections guide if you are unfamiliar with soldering practices.
结论
另外一个人完成了本指南。
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 8
总计 203
