跳转到主内容
Protocol Neo-Drone AP Motor Replacement
你所需要的
  1. Protocol Neo-Drone AP Motor Replacement, Motor: 步骤 1 中的图像 1,2 Protocol Neo-Drone AP Motor Replacement, Motor: 步骤 1 中的图像 2,2
    • Remove the four blades by pulling them off of the motors.
  2. Protocol Neo-Drone AP Motor Replacement: 步骤 2 中的图像 1,1
    • Remove the blade guards by pushing the guards downward towards the padded feet.
  3. Protocol Neo-Drone AP Motor Replacement: 步骤 3 中的图像 1,1
    • Remove the four 4.5mm Phillips #0 screws from the back panel.
  4. Protocol Neo-Drone AP Motor Replacement: 步骤 4 中的图像 1,2 Protocol Neo-Drone AP Motor Replacement: 步骤 4 中的图像 2,2
    • Use the flat end of a spudger to pry apart the the two pieces.
    • Lift the back panel up to separate it from the front panel.
  5. Protocol Neo-Drone AP Motor Replacement: 步骤 5 中的图像 1,1
    • Pull the four motors out of the case.
    • The motors are still soldered to the motherboard.
  6. Protocol Neo-Drone AP Motor Replacement: 步骤 6 中的图像 1,1
    • Here is a link to the iFixit Soldering Guide
    • Use a soldering iron to desolder the motors from the motherboard.
结论
Andrew
于07/05/18注册
291 声望
创作了2篇指南
团队
IUPUI, Team S2-G3, Harley Summer 2018 IUPUI, Team S2-G3, Harley Summer 2018 的会员
IUPUI-HARLEY-SU18S2G3
4 名成员
创作了2篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 12
总计 420
