跳转到主内容
Protocol Kaptur GPS Main Circuit Board Replacement
你所需要的
  1. Protocol Kaptur GPS Main Circuit Board Replacement, Battery: 步骤 1 中的图像 1,2 Protocol Kaptur GPS Main Circuit Board Replacement, Battery: 步骤 1 中的图像 2,2
    • The battery is accessible through the back of the drone.
    • Press the tabs on both sides of the white stripe to pull the battery out.
  2. Protocol Kaptur GPS Main Circuit Board Replacement: 步骤 2 中的图像 1,3 Protocol Kaptur GPS Main Circuit Board Replacement: 步骤 2 中的图像 2,3 Protocol Kaptur GPS Main Circuit Board Replacement: 步骤 2 中的图像 3,3
    • Remove the screws starting with the three smaller ones on the top part of the battery.
    • Remove the three screws on the other side.
    • There are two screws tucked under where the yellow circle is located. You will need to remove the other screws first before you get to these two.
    • There should be one 7 mm Phillips head screw, three 6 mm Phillips head screws, and four 5 mm Phillips head screws.
  3. Protocol Kaptur GPS Main Circuit Board Replacement: 步骤 3 中的图像 1,2 Protocol Kaptur GPS Main Circuit Board Replacement: 步骤 3 中的图像 2,2
    • Remove the top piece, and gently pry the two halves apart. Divide the sticker if necessary.
  4. Protocol Kaptur GPS Main Circuit Board Replacement: 步骤 4 中的图像 1,2 Protocol Kaptur GPS Main Circuit Board Replacement: 步骤 4 中的图像 2,2
    • The battery is now removable from its container.
    • During reassembly, make sure the outlet is returned to its holder and faces the correct direction.
  5. Protocol Kaptur GPS Main Circuit Board Replacement, Main Circuit Board: 步骤 5 中的图像 1,2 Protocol Kaptur GPS Main Circuit Board Replacement, Main Circuit Board: 步骤 5 中的图像 2,2
    • Remove the 4x 7mm screws on the top and bottom, and the 2x 5mm screws from the middle, then remove the back part of the housing.
    • Remove the two hidden screws at the bottom, and the white power button.
    • There will be 6x 7 mm Phillips head screws, and 2x 5 mm Phillips head screws.
  6. Protocol Kaptur GPS Main Circuit Board Replacement: 步骤 6 中的图像 1,3 Protocol Kaptur GPS Main Circuit Board Replacement: 步骤 6 中的图像 2,3 Protocol Kaptur GPS Main Circuit Board Replacement: 步骤 6 中的图像 3,3
    • Unplug all the cords from the circuit boards.
    • Carefully slide the main body right off the arms.
  7. Protocol Kaptur GPS Main Circuit Board Replacement: 步骤 7 中的图像 1,2 Protocol Kaptur GPS Main Circuit Board Replacement: 步骤 7 中的图像 2,2
    • Remove the four 4mm Phillips screws.
    • Desolder all cords on the circuit board, and pull the board up and out.
    • It is important to keep track of where the leads came from. Red/Blue and Black/White pairings belong to motors, whereas Black/Red pairings belong to lights. The ports are labeled on the board.
结论
另外一个人完成了本指南。
Connor Woitte
于02/15/18注册
858 声望
创作了3篇指南
团队
UW Stout, Team S8-G6, Ogden Spring 2018 UW Stout, Team S8-G6, Ogden Spring 2018 的会员
UWSTOUT-OGDEN-S18S8G6
3 名成员
创作了4篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 15
总计 911
