跳转到主内容
Protocol Dronium III AP Light Bulb Replacement
你所需要的
  1. Protocol Dronium III AP Light Bulb Replacement, Drone Battery Pack: 步骤 1 中的图像 1,2 Protocol Dronium III AP Light Bulb Replacement, Drone Battery Pack: 步骤 1 中的图像 2,2
    • Ensure the drone is powered off.
    • Press in and lift battery compartment cover.
    • A soft pry tool may be used for easier access.
  2. Protocol Dronium III AP Light Bulb Replacement: 步骤 2 中的图像 1,1
    • Remove battery pack from body of drone.
  3. Protocol Dronium III AP Light Bulb Replacement: 步骤 3 中的图像 1,2 Protocol Dronium III AP Light Bulb Replacement: 步骤 3 中的图像 2,2
    • Disconnect white connectors between the battery pack and drone.
  4. Protocol Dronium III AP Light Bulb Replacement, L.E.D. Bulb(s): 步骤 4 中的图像 1,1
    • Remove the eight (8) 5mm Philips screws attaching the motor arms to the body using a Philips J00 screwdriver.
  5. Protocol Dronium III AP Light Bulb Replacement: 步骤 5 中的图像 1,2 Protocol Dronium III AP Light Bulb Replacement: 步骤 5 中的图像 2,2
    • Remove the six (6) 5mm Philips screws attaching the Body Cover to the Body of the drone using a Philips J00 screwdriver.
    • Remove the Body Cover.
  6. Protocol Dronium III AP Light Bulb Replacement: 步骤 6 中的图像 1,2 Protocol Dronium III AP Light Bulb Replacement: 步骤 6 中的图像 2,2
    • Remove the two (2) 5mm Philips screws attaching the Motherboard to the body of the drone using a Philips J00 screwdriver.
    • Lift the Motherboard off the mounting position.
    • Do not pull hard on the Motherboard as solder connections are fragile.
  7. Protocol Dronium III AP Light Bulb Replacement: 步骤 7 中的图像 1,2 Protocol Dronium III AP Light Bulb Replacement: 步骤 7 中的图像 2,2
    • This step contains a tool that can present a potential burn hazard.
    • Prepare and warm up a soldering iron.
    • Position Motherboard so that the L.E.D. bulb solder joints are accessible.
    • Use the soldering iron to melt the solder joints.
    • For more detailed instructions on how to solder, visit out How to Solder and Desolder Connections guide.
    • Remove the L.E.D. bulb from the Motherboard
结论
Steven Mooers
于10/18/17注册
401 声望
创作了4篇指南
团队
UW Tacoma, Team S1-G1, Rose Fall 2017 UW Tacoma, Team S1-G1, Rose Fall 2017 的会员
UWT-ROSE-F17S1G1
4 名成员
创作了4篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 6
总计 312
