简介
Like most electronics, after some time the battery life will not be like it used to be. One can tell if the flight of the gyro-copter does not last as long or if there is trouble charging. Replacing the battery pack is not difficult but will require some soldering skills.
你所需要的
Remove the two 5.0 mm Phillips #00 screws from the rotors.
The blades will fall off when the screws have been removed.
Pull the battery off of the holder.
Cut each of the wires to the battery one at a time using a pair of wire cutters.
4等其他人完成本指南。
