跳转到主内容
加入维修社区 - 创建账户
ProntoTec Axius Speaker Replacement
你所需要的
  1. ProntoTec Axius Speaker Replacement, Speaker: 步骤 1 中的图像 1,1
    • Make sure the device is completely turned off before you begging taking it apart to avoid electrocution risks.
    • Place tablet face-up on a flat table.
    询问修复机器人
    添加评论
  2. ProntoTec Axius Speaker Replacement: 步骤 2 中的图像 1,1
    • Starting near the headphone port, fit the flat end of the spudger in between the screen and back case.
    • Pry the back case from the screen around each point on the device to release the clips securing the case halves to each other.
    询问修复机器人
    添加评论
  3. ProntoTec Axius Speaker Replacement: 步骤 3 中的图像 1,1
    • Gently remove the back case of the device and lay it in a flat surface as shown in the photo.
    • Don't pull the back of the device too far apart so it doesn't damage the wires that are connected to the speaker in the back of the device
    询问修复机器人
    添加评论
  4. ProntoTec Axius Speaker Replacement: 步骤 4 中的图像 1,3 ProntoTec Axius Speaker Replacement: 步骤 4 中的图像 2,3 ProntoTec Axius Speaker Replacement: 步骤 4 中的图像 3,3
    • Disconnect the red wire connecting the speaker to the motherboard by using a soldering iron to melt the contact point.
    • Once the solder is melted, use pliers to pull the wire away from the motherboard
    询问修复机器人
    添加评论
  5. ProntoTec Axius Speaker Replacement: 步骤 5 中的图像 1,2 ProntoTec Axius Speaker Replacement: 步骤 5 中的图像 2,2
    • Repeat Step 4 with the black wire connecting the speaker to the motherboard.
    • Don't leave the soldering iron too long on top of the wire so it doesn't melt any other component in the motherboard or surrounding the area.
    • If soldering is new to you, check out this helpful guide on soldering and desoldering connections.
    询问修复机器人
    添加评论
  6. ProntoTec Axius Speaker Replacement: 步骤 6 中的图像 1,2 ProntoTec Axius Speaker Replacement: 步骤 6 中的图像 2,2
    • Using a spudger gently remove the speaker from the back of the device.
    • When working with electronics, it's important to choose a tool that's ESD-safe to avoid accidental damage to the device. The metal spudger is great when you need serious prying power, but the regular black nylon spudger should be used whenever possible.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
团队
UMass Dartmouth, Team 5-3, Martin Fall 2016 UMass Dartmouth, Team 5-3, Martin Fall 2016 的会员
UMASSD-MARTIN-F16S5G3
3 名成员
创作了10篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 24
总计 407
