跳转到主内容
ProntoTec Axius Motherboard Replacement
你所需要的
  1. ProntoTec Axius Motherboard Replacement, Motherboard: 步骤 1 中的图像 1,1
    • Make sure the device is completely turned off before you begging taking it apart to avoid electrocution risks.
    • Place the tablet face-up on a flat table.
  2. ProntoTec Axius Motherboard Replacement: 步骤 2 中的图像 1,1
    • Starting near the headphone port, fit the flat end of the spudger in between the screen and back case.
    • Pry the back case from the screen around each point on the device to release the clips securing the case halves to each other.
  3. ProntoTec Axius Motherboard Replacement: 步骤 3 中的图像 1,1
    • Gently remove the back case of the device and lay it in a flat surface as shown in the photo.
    • Make sure not to sever the wires (red and black) connected to the speaker that is located in the back case.
  4. ProntoTec Axius Motherboard Replacement: 步骤 4 中的图像 1,2 ProntoTec Axius Motherboard Replacement: 步骤 4 中的图像 2,2
    • Remove only the yellow tape that touches the motherboard
    • Be careful not to cut or damage the wires (red and black) that connect the battery to the motherboard.
  5. ProntoTec Axius Motherboard Replacement: 步骤 5 中的图像 1,3 ProntoTec Axius Motherboard Replacement: 步骤 5 中的图像 2,3 ProntoTec Axius Motherboard Replacement: 步骤 5 中的图像 3,3
    • Use a Phillips screwdriver (PH00) to unscrew the two screws that connects the motherboard to the device
    • Be careful not to cut or damage the wires (red and black) that connect the motherboard to the battery.
  6. ProntoTec Axius Motherboard Replacement: 步骤 6 中的图像 1,2 ProntoTec Axius Motherboard Replacement: 步骤 6 中的图像 2,2
    • Using a soldering iron, desolder the contact points of the speaker, battery and screen on the motherboard
    • If soldering is new to you, check out this helpful guide on soldering and desoldering connections.
    • Use pliers to pull the wire from the board
  7. ProntoTec Axius Motherboard Replacement: 步骤 7 中的图像 1,2 ProntoTec Axius Motherboard Replacement: 步骤 7 中的图像 2,2
    • Using the spudger, disconnect the ribbon cable connecting the camera to the motherboard
  8. ProntoTec Axius Motherboard Replacement: 步骤 8 中的图像 1,3 ProntoTec Axius Motherboard Replacement: 步骤 8 中的图像 2,3 ProntoTec Axius Motherboard Replacement: 步骤 8 中的图像 3,3
    • Using the spudger, push the black tabs towards the ribbon cable to unlock the ribbon cables that connect the screen to the motherboard.
    • Gently pull and remove the ribbon cables from the motherboard
  9. ProntoTec Axius Motherboard Replacement: 步骤 9 中的图像 1,2 ProntoTec Axius Motherboard Replacement: 步骤 9 中的图像 2,2
    • Using the flat side of the spudger, lift up the mother board to disconnect from the screen.
结论
另外一个人完成了本指南。
Estelle Hatem
于10/20/16注册
156 声望
撰写一个指南
团队
UMass Dartmouth, Team 5-3, Martin Fall 2016 UMass Dartmouth, Team 5-3, Martin Fall 2016 的会员
UMASSD-MARTIN-F16S5G3
3 名成员
创作了10篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 12
总计 389
