跳转到主内容
Processor of why! Replace W253EU
你所需要的
  1. Processor of why! Replace W253EU, Battery from why! Remove W253EU: 步骤 1 中的图像 1,3 Processor of why! Replace W253EU, Battery from why! Remove W253EU: 步骤 1 中的图像 2,3 Processor of why! Replace W253EU, Battery from why! Remove W253EU: 步骤 1 中的图像 3,3
    • Turn off the computer.
    • Before each operation it is important to start with the removal of the accumulator.
    • Take the slide unlocked into position, remove the battery.
  2. Processor of why! Replace W253EU, Access to RAM and CPU from why! W253EU: 步骤 2 中的图像 1,2 Processor of why! Replace W253EU, Access to RAM and CPU from why! W253EU: 步骤 2 中的图像 2,2
    • Using a Philips #1 screwdriver, unscrew the 5 screws securing the cover.
  3. Processor of why! Replace W253EU: 步骤 3 中的图像 1,3 Processor of why! Replace W253EU: 步骤 3 中的图像 2,3 Processor of why! Replace W253EU: 步骤 3 中的图像 3,3
    • Push the screwdriver a few millimeters under the cover so that it can be touched with your fingers.
    • Now lift the cover carefully.
    • Attention! Disconnect the ventillator cable so that the cover can be completely removed (see next step).
  4. Processor of why! Replace W253EU: 步骤 4 中的图像 1,1
    • Since the ventillator is mounted under the cover, its power supply cable must first be disconnected so that the cover can then be completely removed.
  5. Processor of why! Replace W253EU, processor: 步骤 5 中的图像 1,3 Processor of why! Replace W253EU, processor: 步骤 5 中的图像 2,3 Processor of why! Replace W253EU, processor: 步骤 5 中的图像 3,3
    • Using the Phillips # 1 screwdriver, unscrew the 3 mounting screws of the processor heat sink.
    • Note position of marker triangle as this will determine the positioning of the processor during replacement.
    • Unlock the coupling system of the processor with a classic screwdriver.
    • Make sure that you do not remove the heat-dissipating paste between the processor and the heat sink, as this is the only way to ensure that the processor is properly cooled.
  6. Processor of why! Replace W253EU: 步骤 6 中的图像 1,3 Processor of why! Replace W253EU: 步骤 6 中的图像 2,3 Processor of why! Replace W253EU: 步骤 6 中的图像 3,3
    • Carefully disconnect the processor from its holder.
    • Now place the processor aside, taking into account the position of the triangle.
结论
For reassembly, follow the instructions in the reverse order
由衷感谢以下译者:
de en
100%
这些译者帮助我们修补全世界! 您也想加入吗?
开始翻译 ›
Felice Suglia
于06/15/13注册
31,100 声望
创作了264篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 16
总计 415
