本指南有最近更改,您可查看未经巡查的最新版本。
简介
You can install hard drives up to 12.5mm thick.
你所需要的
Firmly grasp the plastic tab attached to the Airport card and pull up and to the left.
Disconnect the antenna cable from the left side of the Airport card.
Disconnect the hard drive ribbon from the logic board using a spudger or the tip of your finger, removing tape as necessary.
Remove the two black plastic bumpers and two T8 Torx screws from the side of the hard drive.
9等其他人完成本指南。
