Remove the four 3.4 mm Phillips screws from the PC card side of the PowerBook.
When replacing these screws, you must reinstall each screw in the correct order. Begin by installing the screw closest to the display hinge, and go out from there.
Remove the four 3.4 mm Phillips screws from the DVI connector side of the PowerBook.
During reassembly, make sure to reinstall the two screws on the right into their appropriate locations, and not the DVI port anchor holes.
Bow the keyboard out slightly to release the two tabs near the upper corner on each side of the keyboard.
Rotate the keyboard toward yourself and lift it out of the upper case.
When reinstalling your keyboard, make sure to feed both the keyboard and backlight ribbon cables through the slot near the lower edge of the keyboard enclosure on the lower case (shown in red).
