简介
The PRAM battery on your PowerBook gives the RAM power to store startup information when you shut off your computer. Luckily, it is easily accessible.
Use a coin to turn the battery locking screw 90 degrees clockwise.
Lift the battery out of the computer.
Remove the following 10 screws:
Two 3 mm Phillips in the battery compartment, on either side of the battery contacts.
Four 3 mm Phillips around the memory compartment.
Four 16 mm Phillips along the hinge.
Rotate the computer 90 degrees clockwise so the ports face you.
Remove the three 3 mm Phillips screws along the edge of the lower case.
When replacing these screws, you must install them in the correct order. Begin by installing the screw closest to the display hinge, then work your way toward the front of the computer. Also, be careful not to put the screws in the two holes on either side of the video out port.
10等其他人完成本指南。
附加文件
3条评论
It would be helpful to know whether a new PRAM battery unit needs charging as in this article
https://discussions.apple.com/thread/239...
or whether it is assumed that it will start charging in the course of normal use.
It is not standard but you can change it anyway...
