跳转到主内容
PowerBook G3 Pismo Clutch Cover Replacement
你所需要的
  1. PowerBook G3 Pismo Clutch Cover Replacement, Keyboard: 步骤 1 中的图像 1,1
    • Turn the keyboard locking screw so that it is parallel to the space bar.
    • Pull the keyboard release tabs toward you and lift up on the keyboard until it pops free.
    • Lift the keyboard out by pulling it up and away from you. Rest the keyboard, face down, on top of the track pad.
  2. PowerBook G3 Pismo Clutch Cover Replacement: 步骤 2 中的图像 1,1
    • Pull the keyboard ribbon straight up from the logic board. Place the keyboard aside.
    • The connector may be tight. Gently rock the connector from side to side while pulling directly upward to free it. You can use this technique on many of the cards and cables you'll be disconnecting.
    • Make sure you have removed the laptop battery and CD/DVD modules from the expansion bays before proceeding.
  3. PowerBook G3 Pismo Clutch Cover Replacement: 步骤 3 中的图像 1,1
    • Your laptop should look approximately like this.
  4. PowerBook G3 Pismo Clutch Cover Replacement, Heat Shield: 步骤 4 中的图像 1,1
    • Remove the two silver Phillips #1 screws that attach the heat shield to the internal metal framework.
    • Lift the heat shield up and pull it toward you.
  5. PowerBook G3 Pismo Clutch Cover Replacement: 步骤 5 中的图像 1,1
  6. PowerBook G3 Pismo Clutch Cover Replacement, Airport Card: 步骤 6 中的图像 1,1
    • Skip this step if your computer does not have an Airport card installed.
    • Firmly grasp the plastic tab attached to the Airport card and pull up and then to the right.
    • The Airport card is still attached to the antenna cable, so don't just yank it out of the slot.
  7. PowerBook G3 Pismo Clutch Cover Replacement: 步骤 7 中的图像 1,1
    • Disconnect the antenna cable from the Airport card.
  8. PowerBook G3 Pismo Clutch Cover Replacement, PRAM Battery: 步骤 8 中的图像 1,1
    • Pull the battery cable directly up from the logic board.
    • Remove the battery from its holder by pulling up and to the left.
  9. PowerBook G3 Pismo Clutch Cover Replacement: 步骤 9 中的图像 1,1
  10. PowerBook G3 Pismo Clutch Cover Replacement, Heat Sink: 步骤 10 中的图像 1,1
    • Remove the long silver Phillips #1 screw from the heat sink.
    • Remove the two T8 Torx screws that attach the heat sink to the processor.
  11. PowerBook G3 Pismo Clutch Cover Replacement: 步骤 11 中的图像 1,1
    • Lift the heat sink up from the left side and pull it out.
    • If you need to mount the heat sink back into the laptop, we have a thermal paste guide that makes replacing the thermal compound easy.
  12. PowerBook G3 Pismo Clutch Cover Replacement, Processor: 步骤 12 中的图像 1,1
    • Grasp the plastic tab on the processor's right side and pull it directly up.
    • Some processors may be missing the plastic pull tab. In this case, we suggest using a non-metal tool to gently pry up the processor. Slip the tool's thin edge under the front right corner of the processor and carefully pry it up.
  13. PowerBook G3 Pismo Clutch Cover Replacement: 步骤 13 中的图像 1,1
  14. PowerBook G3 Pismo Clutch Cover Replacement, Modem: 步骤 14 中的图像 1,1
    • Remove the black Torx screw from the right side of the modem.
    • Remove the small black plastic rectangle with four holes.
  15. PowerBook G3 Pismo Clutch Cover Replacement: 步骤 15 中的图像 1,1
    • Use the tips of your fingers, a spudger, or a flat non-metal tool to get under the modem's edge and pry it up from its socket.
  16. PowerBook G3 Pismo Clutch Cover Replacement: 步骤 16 中的图像 1,1
    • Disconnect the cable from the right side of the modem.
  17. PowerBook G3 Pismo Clutch Cover Replacement, Hard Drive: 步骤 17 中的图像 1,1
    • Grasp the orange cable at the left end of the hard drive and disconnect it from the logic board.
    • Try to grasp the cable on the plastic connector rather than on the flexible cable section.
  18. PowerBook G3 Pismo Clutch Cover Replacement: 步骤 18 中的图像 1,1
    • Grasp the plastic tab and pull the hard drive up and to the left, making sure that the metal bracket doesn't catch on the black plastic casing.
  19. PowerBook G3 Pismo Clutch Cover Replacement: 步骤 19 中的图像 1,1
  20. PowerBook G3 Pismo Clutch Cover Replacement, Clutch Cover: 步骤 20 中的图像 1,1
    • Push the display back so that it lies flat.
    • Slip your index finger or a nylon tool under the clutch cover near the power button and pull gently upward until you feel it come free.
    • Repeat the previous step on the left side.
  21. PowerBook G3 Pismo Clutch Cover Replacement: 步骤 21 中的图像 1,1
    • Lift the clutch cover up and off, rotating it toward yourself.
结论
2等其他人完成本指南。
附加文件
iRobot
于09/24/09注册
1 声望
创作了636篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 4
总计 5,049
