跳转到主内容
加入维修社区 - 创建账户
PowerBook 2400c Disassembly
你所需要的
  1. PowerBook 2400c Disassembly, Unplug & Remove Battery: 步骤 1 中的图像 1,2 PowerBook 2400c Disassembly, Unplug & Remove Battery: 步骤 1 中的图像 2,2
    • You'll want to check inside the battery compartment. These machines are notorious for their PRAM batteries going critical and leaking electrolytic fluid all over the place. If you see any, grab some gloves.
  2. PowerBook 2400c Disassembly, Remove the screws top plate: 步骤 2 中的图像 1,1
    • Open ther monitor so it folds all the way back for the next steps...
    • Remove the plastic hole covers if needed.
    • Remove the two phillips head screws from the top plate.
  3. PowerBook 2400c Disassembly, Remove the top plate: 步骤 3 中的图像 1,2 PowerBook 2400c Disassembly, Remove the top plate: 步骤 3 中的图像 2,2
    • Using a plastic spudger, pop the hinge clips forward by carefully squeezing them forward.
    • With a spudger, push in the two plastic clips in the front behind the F3 and F12 keys.
    • After the hinge covers are loostened, insert your spudger and loosen the rest of the top clips across the back.
    • The top plate should come free.
  4. PowerBook 2400c Disassembly, Remove the thin top plate: 步骤 4 中的图像 1,1
    • Use the spudger to push the small plate away from the monitor clips, it should come free easily.
  5. PowerBook 2400c Disassembly, Remove keyboard cover: 步骤 5 中的图像 1,2 PowerBook 2400c Disassembly, Remove keyboard cover: 步骤 5 中的图像 2,2
    • Use your fingers to pull the keyboard cover straight back towards you to release the cips.
    • The trackpad ribbon is still attached. Tilt the keyboard cover towards you to reveal the ribbon cable connector.
    • Loosen the trackpad ribbon cable and remove the ribbon.
    • Set the keyboard cover aside.
  6. PowerBook 2400c Disassembly, Remove the keyboard: 步骤 6 中的图像 1,3 PowerBook 2400c Disassembly, Remove the keyboard: 步骤 6 中的图像 2,3 PowerBook 2400c Disassembly, Remove the keyboard: 步骤 6 中的图像 3,3
    • Remove 3 x silver 3mm phillips screws from the top of the keyboard.
    • Remove 3x black 8mm screws from the bottom.
    • Lift the back of the keyboard (the end by the screen) slightly and move it forward to release it from the metal clips at the bottom left. You can then flip the keyboard over and set it on top of the screen.
    • Using a spudger, release the clips from the keyboard connectors and remove the cables from the connectors.
    • You can now remove the keyboard and set it aside.
  7. PowerBook 2400c Disassembly, Remove the IR assembly: 步骤 7 中的图像 1,1
    • Use a spudger to disconnect the IR assembly ribbon cable from the board.
    • Remove the black 22mm phillips screw from the right side of the assembly.
    • Remove the silver 3mm phillips screw from the left of the assembly.
    • You can now remove the IR assembly and set aside.
  8. PowerBook 2400c Disassembly, Disconnect the screen: 步骤 8 中的图像 1,1
    • Remove the black 15mm phillips screw to disconnect the screen ground.
    • Using a spudger, remove the 1st lcd connector.
    • Using a spudger, remove the 2nd LCD connector.
  9. PowerBook 2400c Disassembly, Remove the LCD assembly: 步骤 9 中的图像 1,2 PowerBook 2400c Disassembly, Remove the LCD assembly: 步骤 9 中的图像 2,2
    • Before continuing, adjust the screen to a 90 degree angle.
    • Remove the 2 black 8mm screws from the back.
    • In the next step, support the screen with one hand.
    • Remove the 2 silver 3mm phillips screws from the front.
    • You can now lift the screen up and out of the chassis.
    • If all your doing is replacing the LCD assembly you can stop here!
  10. PowerBook 2400c Disassembly, Remove shielding: 步骤 10 中的图像 1,3 PowerBook 2400c Disassembly, Remove shielding: 步骤 10 中的图像 2,3 PowerBook 2400c Disassembly, Remove shielding: 步骤 10 中的图像 3,3
    • Remove the black 16mm phillips screw.
    • You can now remove this shielding.
    • Make sure to remove and set aside the small spring attached underneath the screw.
    • Remove the two black 8mm phillips screws.
    • You can now lift off the large shielding. Be careful to remove the metal clips on the front of the shielding.
    • If you are only replacing or upgrading the RAM you can stop here!
  11. PowerBook 2400c Disassembly, Remove top metal frame: 步骤 11 中的图像 1,2 PowerBook 2400c Disassembly, Remove top metal frame: 步骤 11 中的图像 2,2
    • Using a spudger, disconnect the display sleep switch from the board.
    • Remove the 3 black 8mm phillips screws from the outside of the top frame.
    • Remove the 1 black 22mm phillips screw from the top right of the top frame.
    • Remove the 1 black 14mm phillips screw from the middle left of the top frame.
    • Remove the 1 black 4mm phillips screw from the left of the top frame.
    • Lift off the top frame, being careful to unravel the sleep switch cable from around the SCSI port.
  12. PowerBook 2400c Disassembly, Remove system board assembly: 步骤 12 中的图像 1,3 PowerBook 2400c Disassembly, Remove system board assembly: 步骤 12 中的图像 2,3 PowerBook 2400c Disassembly, Remove system board assembly: 步骤 12 中的图像 3,3
    • Remove the 2 silver 3.5mm phillips screws from the shielding on the right of the board. You can then remove and set aside the shielding.
    • Remove the 3 remaining silver 3.5mm phillips screws from the system board.
    • Remove the 2 black 16mm phillips screws from the right of the board.
    • Remove the 1 silver 14mm phillips screw from the center of the board.
    • Using a spudger, disconnect the audio cable from the board.
    • Carefully remove the audio port cover by gently twisting upward and lifting out.
    • The main system board is connected to the daugter board below. Using a spudger where indicated to gently coax the board free from the connector below.
    • You can now lift the main board out of the case.
  13. PowerBook 2400c Disassembly, Remove hard drive: 步骤 13 中的图像 1,2 PowerBook 2400c Disassembly, Remove hard drive: 步骤 13 中的图像 2,2
    • Remove the 2 black 3.5mm phillips screws from the bottom side of the board.
    • The hard disk will only be connected by the IDE connector. Support the hard drive with your hand while turning the board over.
    • Gently, but firmly remove the hard drive from the IDE connector by wiggling back and forth slightly and pulling back toward the side of the board.
    • If you have made it this far, DO NOT STOP HERE. It's virtually impossible to re-seat the system board correctly without disassembling further. Proceed to the next step!
  14. PowerBook 2400c Disassembly: 步骤 14 中的图像 1,1
    • Remove the single black 16mm phillips screw holding the plastic assembly to the bottom case.
    • Lift the front of the board (closest to you) to pull the assembly out of the case, making sure clear the ports in the back.
  15. PowerBook 2400c Disassembly, Re-seating the system board: 步骤 15 中的图像 1,3 PowerBook 2400c Disassembly, Re-seating the system board: 步骤 15 中的图像 2,3 PowerBook 2400c Disassembly, Re-seating the system board: 步骤 15 中的图像 3,3
    • The plastic frame isn't very sturdy. Be sure to support it appropriately while you're working with it.
    • Place the system board on top of the assembly so the PCMCIA slot is to the left of the ports.
    • Carefully flip the assembly over.
    • While supporting the back, gently apply pressure to the highligted area to re-seat the boards. You should feel a positive fit.
  16. PowerBook 2400c Disassembly: 步骤 16 中的图像 1,1
    • Place the boards back into the chassis by tilting to board to the back and inserting them port-first.
    • Replace the black 16mm phillips screw.
    • Replace the small spring.
    • Continue re-assembly by going back to Step 12 of the guide and follow the steps in reverse from there.
结论
To reassemble your device, make sure you complete the guide.
6等其他人完成本指南。
polymatt
于07/24/21注册
2,061 声望
创作了8篇指南
3指南评论
Thank you for posting this guide - I would not be able to successfully disassemble and then reassemble this machine without this help. The first time I disassembled and reassembled my 2400c it would not boot. But then I did it again and now it's booting.
feinberj - 回复
Glad to hear this guide helped! The 2400c is such a great little notebook.
polymatt - 回复
This was perfect. Thank you so much.
Nick Bonevelle - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 16
过去 30 天: 83
总计 1,862
