跳转到主内容
PowerA Spectra Controller Buttons Replacement
你所需要的
  1. PowerA Spectra Controller Buttons Replacement, Rear Case: 步骤 1 中的图像 1,1
    • Flip the controller over so the backplate is facing up.
  2. PowerA Spectra Controller Buttons Replacement: 步骤 2 中的图像 1,1
    • Use a Phillips #2 screwdriver to remove the eight 7.8 mm screws that secure the rear case.
  3. PowerA Spectra Controller Buttons Replacement: 步骤 3 中的图像 1,1
    • Hold the front case in one hand and pull the rear case off.
  4. PowerA Spectra Controller Buttons Replacement, Buttons: 步骤 4 中的图像 1,1
    • Use a Phillips screwdriver to remove the two 7.8 mm screws securing the motherboard to the chassis.
  5. PowerA Spectra Controller Buttons Replacement: 步骤 5 中的图像 1,1
    • Pull the motherboard away from the controller to access the buttons.
    • The motherboard is not fully removable because it is attached to the D-Pad. Be careful not to rip the motherboard from the D-Pad.
  6. PowerA Spectra Controller Buttons Replacement: 步骤 6 中的图像 1,1
    • Pull the old buttons out of the shell of the controller using the angled tweezers.
结论
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 10
总计 147
