跳转到主内容
Polyconcept 900-MHz Retro Cordless Telephone Device Motherboard Replacement
你所需要的
  1. Polyconcept 900-MHz Retro Cordless Telephone Device Motherboard Replacement, Removing Power and Telephone Cords: 步骤 1 中的图像 1,3 Polyconcept 900-MHz Retro Cordless Telephone Device Motherboard Replacement, Removing Power and Telephone Cords: 步骤 1 中的图像 2,3 Polyconcept 900-MHz Retro Cordless Telephone Device Motherboard Replacement, Removing Power and Telephone Cords: 步骤 1 中的图像 3,3
    • To disconnect the phone cord, squeeze the tab against the connector and pull the cord away from the telephone-line-in-jack.
    • To disconnect the power cord, grasp the end and pull back and away until it is disconnected.
    • Once disconnected remove each cord from its track.
  2. Polyconcept 900-MHz Retro Cordless Telephone Device Motherboard Replacement, Removing Screws to Base Plate: 步骤 2 中的图像 1,1
    • Using a Phillips #00 screwdriver, remove the six 7mm screws from the base plate.
  3. Polyconcept 900-MHz Retro Cordless Telephone Device Motherboard Replacement, Remove Bottom Plate from Base: 步骤 3 中的图像 1,3 Polyconcept 900-MHz Retro Cordless Telephone Device Motherboard Replacement, Remove Bottom Plate from Base: 步骤 3 中的图像 2,3 Polyconcept 900-MHz Retro Cordless Telephone Device Motherboard Replacement, Remove Bottom Plate from Base: 步骤 3 中的图像 3,3
    • With the base turned upside down, grasp the edges of the base plate and gently lift from the rest of the base.
    • Two wires lead from the motherboard to the charger plate, so the two parts cannot be completely separated without further steps.
  4. Polyconcept 900-MHz Retro Cordless Telephone Device Motherboard Replacement, Removing Screws: 步骤 4 中的图像 1,1
    • Use a Phillips #00 screwdriver to remove the three 6mm screws from the phone and power jack cover plate.
    • Lift the phone and power jack cover plate away from the motherboard.
  5. Polyconcept 900-MHz Retro Cordless Telephone Device Motherboard Replacement, Removing the Motherboard Screw: 步骤 5 中的图像 1,1
    • Use a Philips #00 screwdriver to remove the single 6mm screw from the motherboard.
  6. Polyconcept 900-MHz Retro Cordless Telephone Device Motherboard Replacement, Removing Glue Covering for Wire Connections: 步骤 6 中的图像 1,2 Polyconcept 900-MHz Retro Cordless Telephone Device Motherboard Replacement, Removing Glue Covering for Wire Connections: 步骤 6 中的图像 2,2
    • Use the spudger tool to carefully scrape the glue off of the connection points of both the black and red wires.
  7. Polyconcept 900-MHz Retro Cordless Telephone Device Motherboard Replacement, Desoldering Wire Connections: 步骤 7 中的图像 1,1
    • Gently lift the motherboard away from the base plate and flip over.
    • Use the soldering station to desolder the wire connections.
    • For further instructions on using the soldering station click here.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 8
总计 392
