跳转到主内容
加入维修社区 - 创建账户
Polaroid PTAB7XC Screen Replacement
浏览量: 981
浏览统计数据:
过去24小时
3
过去 7 天:
13
过去 30 天:
65
总计
981
评论: 0
暂时还没有人对本指南发表评论。你想做第一个评论的人吗?
Go to guide comments
已完成: 1
1 人已将本指南标记为“已完成”。你会是下一个完成的人吗?
收藏: 1
1 人收藏(并订阅)了本指南。你会是下一个吗?
所需时间: 30分钟
难度: 困难
This process requires desoldering and the removal of many components. For more on information about soldering see here. However, replacing the screen for this device is not as difficult as screen replacement for many other devices.
你所需要的
工具
    1. Polaroid PTAB7XC Screen Replacement, Screen: 步骤 1 中的图像 1,2 Polaroid PTAB7XC Screen Replacement, Screen: 步骤 1 中的图像 2,2
      • Remove the two 7 mm screws on the top of the device using a J00 Phillips screwdriver and by turning the screws counterclockwise.
      • If the screw heads have corroded or been stripped, it may be necessary to use a larger screwdriver head, such as the J0.
      询问修复机器人
      添加评论
    2. Polaroid PTAB7XC Screen Replacement: 步骤 2 中的图像 1,3 Polaroid PTAB7XC Screen Replacement: 步骤 2 中的图像 2,3 Polaroid PTAB7XC Screen Replacement: 步骤 2 中的图像 3,3
      • Pry the seam between the screen and the case on all four sides with a large plastic opening tool until the plastic case comes off.
      • Lift the device off of the case and flip over the device so that it sits screen side down.
      • The device is now free from the plastic casing.
      • The power and/or volume buttons may fall out at this point. There is no problem with this; however, be sure to remember to reinstall them when reassembling the device.
      询问修复机器人
      添加评论
    3. Polaroid PTAB7XC Screen Replacement: 步骤 3 中的图像 1,2 Polaroid PTAB7XC Screen Replacement: 步骤 3 中的图像 2,2
      在这个步骤中使用的工具:
      Plastic Cards
      $2.99
      • Wedge a plastic card beneath the battery unit.
      • Wiggle the card side to side and up and down gently until the glue sealing the battery to the device is broken.
      • Do not rupture the battery; it poses a serious safety hazard.
      • There is a plastic bag around the battery; if torn or stretched, there is no safety hazard.
      询问修复机器人
      添加评论
    4. Polaroid PTAB7XC Screen Replacement: 步骤 4 中的图像 1,3 Polaroid PTAB7XC Screen Replacement: 步骤 4 中的图像 2,3 Polaroid PTAB7XC Screen Replacement: 步骤 4 中的图像 3,3
      • Desolder the following components from the motherboard.
      • Desolder from the motherboard the red wire that connects to the speaker unit.
      • Desolder from the motherboard the black wire that connects to the speaker unit.
      • Desolder from the motherboard the gray wire that runs along the edge of the device.
      • The motherboard will now be detached from any wires connecting to the device except for those attached to the battery.
      询问修复机器人
      添加评论
    5. Polaroid PTAB7XC Screen Replacement: 步骤 5 中的图像 1,3 Polaroid PTAB7XC Screen Replacement: 步骤 5 中的图像 2,3 Polaroid PTAB7XC Screen Replacement: 步骤 5 中的图像 3,3
      在这个步骤中使用的工具:
      • Use tweezers to unstick the medium width yellow ribbon cable from the motherboard.
      • Use a small opening tool to slide the two small black holding clips off of the white connector to which the medium width yellow ribbon cable is attached.
      • Use your fingers to gently pull the medium width yellow ribbon cable out of the white connector.
      • Repeat the last two actions to disconnect the narrower yellow ribbon cable and the wider yellow ribbon cable from the motherboard.
      • The motherboard and battery will now be detached from any ribbon cables connecting to the device.
      询问修复机器人
      添加评论
    6. Polaroid PTAB7XC Screen Replacement: 步骤 6 中的图像 1,3 Polaroid PTAB7XC Screen Replacement: 步骤 6 中的图像 2,3 Polaroid PTAB7XC Screen Replacement: 步骤 6 中的图像 3,3
      • Use the PH000 screwdriver remove the four 5 mm screws along the bottom edge of the motherboard, turning them counterclockwise.
      询问修复机器人
      添加评论
    7. Polaroid PTAB7XC Screen Replacement: 步骤 7 中的图像 1,1
      • Lift the motherboard and battery out of the device using your hands.
      • The back of the display and the speaker unit will now be visible and accessible
      询问修复机器人
      添加评论
    8. Polaroid PTAB7XC Screen Replacement: 步骤 8 中的图像 1,1
      • Remove the 5mm screw that holds the speaker unit on to the display unit using a J000 screwdriver, turning the screws counterclockwise.
      询问修复机器人
      添加评论
    9. Polaroid PTAB7XC Screen Replacement: 步骤 9 中的图像 1,1
      • Using thumb and forefinger, remove the speaker unit from the device
      询问修复机器人
      添加评论
    10. Polaroid PTAB7XC Screen Replacement: 步骤 10 中的图像 1,1
      • Using a J000 Philips head screwdriver, remove the two 5mm screws that hold the display unit down at the bottom of the device, turning the screws counterclockwise.
      询问修复机器人
      添加评论
    11. Polaroid PTAB7XC Screen Replacement: 步骤 11 中的图像 1,1
      • Lift the small black display protector that was between the screws and the display unit using your forefinger and thumb.
      询问修复机器人
      添加评论
    12. Polaroid PTAB7XC Screen Replacement: 步骤 12 中的图像 1,1
      • Using both hands, lift up the device.
      • Using your fingers, push upward from below on the screen until the screen and display unit pop out of the black plastic frame.
      • The screen and display unit should now be separated from the plastic casing.
      • Set the screen and display unit screen-side down.
      询问修复机器人
      添加评论
    13. Polaroid PTAB7XC Screen Replacement: 步骤 13 中的图像 1,2 Polaroid PTAB7XC Screen Replacement: 步骤 13 中的图像 2,2
      • Wedge the large plastic opening tool into one of the notches on the edge of the screen and display unit.
      • Pry until a small tab pops out of the notch.
      • Repeat on every notch around the edge of the screen and display unit.
      询问修复机器人
      添加评论
    14. Polaroid PTAB7XC Screen Replacement: 步骤 14 中的图像 1,1
      • Using your fingers, lift the display unit off of the screen.
      • The screen is now replaceable.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
另外一个人完成了本指南。
作者
与
Meg Lybbert
于10/08/15注册
649 声望
创作了5篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 13
过去 30 天: 65
总计 981
