跳转到主内容
Polaroid Now+ (Gen 3) Film Door Replacement
你所需要的
  1. Polaroid Now+ (Gen 3) Film Door Replacement, Safety precautions: 步骤 1 中的图像 1,2 Polaroid Now+ (Gen 3) Film Door Replacement, Safety precautions: 步骤 1 中的图像 2,2
    • If you have any film left, take some photos! Then remove the cartridge. Disassembly will expose any leftover film.
    • Before you begin:
    • Unplug and fully power down your camera.
    • Put on the lens cap to avoid scratching your lens during disassembly.
  2. Polaroid Now+ (Gen 3) Film Door Replacement, Open the film door: 步骤 2 中的图像 1,3 Polaroid Now+ (Gen 3) Film Door Replacement, Open the film door: 步骤 2 中的图像 2,3 Polaroid Now+ (Gen 3) Film Door Replacement, Open the film door: 步骤 2 中的图像 3,3
    • Throughout this guide, directional words (front, back, left, right) are from the perspective of using the camera—or when the lens faces away from you.
    • Hold down the latch on the left side of the camera and open the film door.
  3. Polaroid Now+ (Gen 3) Film Door Replacement, Remove the rear shell screw: 步骤 3 中的图像 1,3 Polaroid Now+ (Gen 3) Film Door Replacement, Remove the rear shell screw: 步骤 3 中的图像 2,3 Polaroid Now+ (Gen 3) Film Door Replacement, Remove the rear shell screw: 步骤 3 中的图像 3,3
    在这个步骤中使用的工具:
    Magnetic Project Mat
    $16.96
    • Use a Phillips screwdriver to remove the 5.9 mm‑long screw securing the rear shell.
    • The screw is hidden inside the camera on the back edge—you may need to use a flashlight to see it, as well as a skinny, long‑shank screwdriver to reach it.
    • Be careful when removing your screwdriver, as the screw can easily fall inside the camera. If it does, hold the camera above your work surface and gently shake it so the screw falls out.
  4. Polaroid Now+ (Gen 3) Film Door Replacement, Release the rear shell clips: 步骤 4 中的图像 1,3 Polaroid Now+ (Gen 3) Film Door Replacement, Release the rear shell clips: 步骤 4 中的图像 2,3 Polaroid Now+ (Gen 3) Film Door Replacement, Release the rear shell clips: 步骤 4 中的图像 3,3
    • Insert the flat edge of an opening pick in the seam between the front and rear shells, just above the USB‑C port on the right edge.
    • Use your pick to pry the rear shell away from the front shell.
    • Keep the inserted edge of the pick pointed toward the rear shell when separating it. This helps release the tight plastic clips holding them together.
  5. Polaroid Now+ (Gen 3) Film Door Replacement: 步骤 5 中的图像 1,3 Polaroid Now+ (Gen 3) Film Door Replacement: 步骤 5 中的图像 2,3 Polaroid Now+ (Gen 3) Film Door Replacement: 步骤 5 中的图像 3,3
    • You should feel and hear distinct "clicks" as the clips release. If you don't, try again—it may take multiple attempts.
    • Slide your pick around the top right corner and along the top edge to release the clips.
  6. Polaroid Now+ (Gen 3) Film Door Replacement: 步骤 6 中的图像 1,3 Polaroid Now+ (Gen 3) Film Door Replacement: 步骤 6 中的图像 2,3 Polaroid Now+ (Gen 3) Film Door Replacement: 步骤 6 中的图像 3,3
    • Continue sliding your pick along the top edge, around the top left corner, and down the left edge to release the clips. Stop when you get to the film door latch.
  7. Polaroid Now+ (Gen 3) Film Door Replacement: 步骤 7 中的图像 1,1
    • Gently flip the camera over, making sure none of the clips re‑engage.
  8. Polaroid Now+ (Gen 3) Film Door Replacement: 步骤 8 中的图像 1,3 Polaroid Now+ (Gen 3) Film Door Replacement: 步骤 8 中的图像 2,3 Polaroid Now+ (Gen 3) Film Door Replacement: 步骤 8 中的图像 3,3
    • Remember to keep the inserted edge of the pick pointed towards the rear shell.
    • Insert your opening pick in the seam near the USB‑C port and slide it around the corner and along the bottom edge to release the remaining clips.
  9. Polaroid Now+ (Gen 3) Film Door Replacement, Camera mirror warning: 步骤 9 中的图像 1,2 Polaroid Now+ (Gen 3) Film Door Replacement, Camera mirror warning: 步骤 9 中的图像 2,2
    • Removing the rear shell in the next step exposes the camera mirror. Be careful not to smudge it or get any debris on it. If you accidentally do, use a lint‑free cloth to gently wipe the mirror clean.
  10. Polaroid Now+ (Gen 3) Film Door Replacement, Remove the rear shell: 步骤 10 中的图像 1,2 Polaroid Now+ (Gen 3) Film Door Replacement, Remove the rear shell: 步骤 10 中的图像 2,2
    • Gently pull the rear shell off the main body of the camera.
    • The shell should slide off easily. If it doesn't, check to see if any clips re‑engaged and use your opening pick to release them.
    • During reassembly:
    • Press the shell firmly onto the main body so all the clips engage.
    • You should feel and hear distinct "clicks" as the clips engage.
    • Check around the shell seam and make sure there are no gaps. If there are, firmly press the shells together to engage the clip near the gap.
  11. Polaroid Now+ (Gen 3) Film Door Replacement, Capacitor warning: 步骤 11 中的图像 1,2 Polaroid Now+ (Gen 3) Film Door Replacement, Capacitor warning: 步骤 11 中的图像 2,2
    • The capacitor in your camera holds an electrical charge and can deliver a potentially dangerous electric shock if you touch the boards incorrectly.
    • To minimize risk, avoid touching the boards, wires, and other exposed components with your fingers or metal tools. Consider wearing rubber gloves if working near the board.
  12. Polaroid Now+ (Gen 3) Film Door Replacement, Flip your camera over: 步骤 12 中的图像 1,1
    • Flip your camera over so the bottom is facing up.
  13. Polaroid Now+ (Gen 3) Film Door Replacement, Remove the film door screws: 步骤 13 中的图像 1,2 Polaroid Now+ (Gen 3) Film Door Replacement, Remove the film door screws: 步骤 13 中的图像 2,2
    • Use a Phillips screwdriver to remove the two 3 mm‑long film door hinge screws (one on either side of the camera).
  14. Polaroid Now+ (Gen 3) Film Door Replacement, Insert a clean cloth: 步骤 14 中的图像 1,3 Polaroid Now+ (Gen 3) Film Door Replacement, Insert a clean cloth: 步骤 14 中的图像 2,3 Polaroid Now+ (Gen 3) Film Door Replacement, Insert a clean cloth: 步骤 14 中的图像 3,3
    • Open the film door and place a clean cloth in the compartment.
    • This prevents the door from re‑securing while detaching the hinges.
  15. Polaroid Now+ (Gen 3) Film Door Replacement, Detach the film door: 步骤 15 中的图像 1,3 Polaroid Now+ (Gen 3) Film Door Replacement, Detach the film door: 步骤 15 中的图像 2,3 Polaroid Now+ (Gen 3) Film Door Replacement, Detach the film door: 步骤 15 中的图像 3,3
    • The small, plastic grommets inside the film door hinges can easily fall off during this step. Don't lose them—you'll need them for reassembly.
    • Use the flat end of a spudger to push one of the film door hinges away from the camera and off its post.
    • Repeat the process to detach the other hinge.
    • Hold the film door steady so the already detached hinge doesn't slide back into place.
  16. Polaroid Now+ (Gen 3) Film Door Replacement: 步骤 16 中的图像 1,3 Polaroid Now+ (Gen 3) Film Door Replacement: 步骤 16 中的图像 2,3 Polaroid Now+ (Gen 3) Film Door Replacement: 步骤 16 中的图像 3,3
    • Check to see if either of the small, plastic hinge grommets stayed on their posts.
    • If they did, remove them and set them aside.
  17. Polaroid Now+ (Gen 3) Film Door Replacement, Remove the film door: 步骤 17 中的图像 1,3 Polaroid Now+ (Gen 3) Film Door Replacement, Remove the film door: 步骤 17 中的图像 2,3 Polaroid Now+ (Gen 3) Film Door Replacement, Remove the film door: 步骤 17 中的图像 3,3
    • Lift the film door and remove it.
    • At this point, you can remove the cloth from the film door compartment.
    • Make sure there are grommets installed in the film door hinges. To install them, press the grommets into the film door hinges, with the wide end facing in.
    • Hook one of the hinges on its post and then push the other one into place until it snaps over its post.
结论
Spencer Day
于09/14/22注册
149,209 声望
创作了995篇指南
团队
iFixit iFixit 的会员
Staff
123 名成员
创作了23,608篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 31
总计 229
