跳转到主内容
Polaroid Flip Bottom Shell Replacement
你所需要的
  1. Polaroid Flip Bottom Shell Replacement, Before you begin: 步骤 1 中的图像 1,3 Polaroid Flip Bottom Shell Replacement, Before you begin: 步骤 1 中的图像 2,3 Polaroid Flip Bottom Shell Replacement, Before you begin: 步骤 1 中的图像 3,3
    • If you have any film left, take some photos! Then remove the cartridge. Disassembly will expose any leftover film.
    • Before you begin:
    • Unplug all cables from your camera.
    • Fully close the flash unit at the front of the camera to turn it off.
  2. Polaroid Flip Bottom Shell Replacement, Open the film door: 步骤 2 中的图像 1,3 Polaroid Flip Bottom Shell Replacement, Open the film door: 步骤 2 中的图像 2,3 Polaroid Flip Bottom Shell Replacement, Open the film door: 步骤 2 中的图像 3,3
    • Throughout this guide, directional words (front, back, left, right) are from the perspective of using the camera—or when the lens faces away from you.
    • Hold down the latch on the left side of the camera and open the film door.
  3. Polaroid Flip Bottom Shell Replacement, Remove the bottom shell screw: 步骤 3 中的图像 1,3 Polaroid Flip Bottom Shell Replacement, Remove the bottom shell screw: 步骤 3 中的图像 2,3 Polaroid Flip Bottom Shell Replacement, Remove the bottom shell screw: 步骤 3 中的图像 3,3
    在这个步骤中使用的工具:
    Magnetic Project Mat
    $19.95
    • Use a Phillips screwdriver to remove the 5.9 mm‑long screw securing the rear shell.
    • The screw is hidden inside the camera on the back edge—you may need to use a flashlight to see it, as well as a skinny, long‑shank screwdriver to reach it.
    • Be careful when removing your screwdriver, as the screw can easily fall inside the camera. If it does, hold the camera above your work surface and gently shake it so the screw falls out.
  4. Polaroid Flip Bottom Shell Replacement, Camera mirror warning: 步骤 4 中的图像 1,2 Polaroid Flip Bottom Shell Replacement, Camera mirror warning: 步骤 4 中的图像 2,2
    • Removing the bottom shell in the next step exposes the camera mirror. Be careful not to smudge it or get any debris on it. If you accidentally do, use a lint‑free cloth to gently wipe the mirror clean.
  5. Polaroid Flip Bottom Shell Replacement, Remove the bottom shell: 步骤 5 中的图像 1,3 Polaroid Flip Bottom Shell Replacement, Remove the bottom shell: 步骤 5 中的图像 2,3 Polaroid Flip Bottom Shell Replacement, Remove the bottom shell: 步骤 5 中的图像 3,3
    • Slide the bottom shell towards the back of the camera to release the clips securing it.
    • Lift and remove the shell.
    • During reassembly:
    • Place the shell onto the frame so it hangs over the back about about half an inch (~13 mm), creating a gap near the center of the camera. This allows room for the clips to slide into place.
    • Push down on the shell and slide it towards the front of the camera to engage the clips—you should feel them slide into place.
结论
Spencer Day
于09/14/22注册
155,036 声望
创作了1,033篇指南
团队
iFixit iFixit 的会员
Staff
123 名成员
创作了23,779篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 12
总计 165
