跳转到主内容
加入维修社区 - 创建账户
Polaroid Flash Unit Shell Replacement
你所需要的
  1. Polaroid Flash Unit Shell Replacement, Before you begin: 步骤 1 中的图像 1,1
    • If you have any film left, take some photos! Then remove the cartridge. Disassembly will expose any leftover film.
    • Unplug all cables from your camera.
  2. Polaroid Flash Unit Shell Replacement, Open your camera: 步骤 2 中的图像 1,2 Polaroid Flash Unit Shell Replacement, Open your camera: 步骤 2 中的图像 2,2
    • Fully open the flash unit at the front of your camera.
  3. Polaroid Flash Unit Shell Replacement, Remove the screw cover: 步骤 3 中的图像 1,3 Polaroid Flash Unit Shell Replacement, Remove the screw cover: 步骤 3 中的图像 2,3 Polaroid Flash Unit Shell Replacement, Remove the screw cover: 步骤 3 中的图像 3,3
    • Slide the tip of an opening pick under the right edge of the screw cover, near the flash.
    • Leave the pick inserted under the cover for the next step.
  4. Polaroid Flash Unit Shell Replacement: 步骤 4 中的图像 1,3 Polaroid Flash Unit Shell Replacement: 步骤 4 中的图像 2,3 Polaroid Flash Unit Shell Replacement: 步骤 4 中的图像 3,3
    • Slide the cover towards the flash to release the clips securing it.
    • Your pick might fall out—that's fine.
    • Pull the cover straight away from the camera and remove it.
  5. Polaroid Flash Unit Shell Replacement, Remove the flash unit shell screws: 步骤 5 中的图像 1,3 Polaroid Flash Unit Shell Replacement, Remove the flash unit shell screws: 步骤 5 中的图像 2,3 Polaroid Flash Unit Shell Replacement, Remove the flash unit shell screws: 步骤 5 中的图像 3,3
    • Hold the flash unit open with one hand.
    • With your free hand, use a Phillips screwdriver to remove the three 5.9 mm‑long screws securing the flash unit shell.
  6. Polaroid Flash Unit Shell Replacement, Remove the flash unit shell: 步骤 6 中的图像 1,3 Polaroid Flash Unit Shell Replacement, Remove the flash unit shell: 步骤 6 中的图像 2,3 Polaroid Flash Unit Shell Replacement, Remove the flash unit shell: 步骤 6 中的图像 3,3
    • Fully close the flash unit for a better grip on the shell.
    • Secure the camera with one hand, and firmly grip the flash unit shell with the other.
    • Lift the right edge of the shell (the side closest to the charging port) to release the clips securing it.
    • You should feel and hear "clicks" as the clips release.
    • Pull the shell up and away from the camera to remove it.
    • During reassembly, put the shell in place and push down firmly to engage the clips.
结论
Spencer Day
于09/14/22注册
158,226 声望
创作了1,043篇指南
团队
iFixit iFixit 的会员
Staff
123 名成员
创作了23,891篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 6
过去 30 天: 24
总计 207
