跳转到主内容
Polar V800 Motherboard Replacement
你所需要的
  1. Polar V800 Motherboard Replacement, Waterproofing Seal: 步骤 1 中的图像 1,2 Polar V800 Motherboard Replacement, Waterproofing Seal: 步骤 1 中的图像 2,2
    • In this guide, the wrist band of the Polar V800 is removed for a clear view of the back panel. If you find it helpful, you may want to remove the wrist strap. Please reference the Watch Band Replacement guide for removal instructions if you wish to do so.
    • Ensure your Polar V800 sports watch is powered off before continuing.
    • Remove the eight, 7.4 millimeter-long screws on the back of the watch with a T5 head-type, torque screwdriver.
  2. Polar V800 Motherboard Replacement: 步骤 2 中的图像 1,3 Polar V800 Motherboard Replacement: 步骤 2 中的图像 2,3 Polar V800 Motherboard Replacement: 步骤 2 中的图像 3,3
    • Gently separate the watch housing from the back panel.
    • The watch should come apart easily after removing the screws. If you experience difficulties separating the housing and and back cover, use a spudger to gently pry apart the back panel and the button and screen protector housing.
  3. Polar V800 Motherboard Replacement: 步骤 3 中的图像 1,2 Polar V800 Motherboard Replacement: 步骤 3 中的图像 2,2
    • The waterproofing seal is the red, elastic band that surrounds the display of the watch.
    • Remove the waterproofing seal.
    • During reassembly, align the red seal in the groove surrounding the glass screen on the main watch housing to ensure a watertight seal.
  4. Polar V800 Motherboard Replacement, Motherboard: 步骤 4 中的图像 1,3 Polar V800 Motherboard Replacement, Motherboard: 步骤 4 中的图像 2,3 Polar V800 Motherboard Replacement, Motherboard: 步骤 4 中的图像 3,3
    • Though not necessary, following the Polar V800 Display Replacement first may make the motherboard easier to remove.
    • Remove the nine, 4.0 millimeter-long screws with a T5 head-type torque screwdriver.
  5. Polar V800 Motherboard Replacement: 步骤 5 中的图像 1,1
    • Once all of the screws have been removed, lift the motherboard to expose the battery beneath motherboard.
    • A red wire and a black wire should run between the motherboard and the battery.
  6. Polar V800 Motherboard Replacement: 步骤 6 中的图像 1,1
    • The battery is glued down to the back of the watch. It may take some force to detach the battery at the glue joint.
    • Use a spudger to pry the battery from the back of the watch.
    • If your battery is swollen, be very careful in removing the battery. If the packaging is ruptured, the battery will be unsafe to handle with bare hands. The contents of the battery are hazardous.
    Original: 3.7 V 442830
    Replacement: 3.7 V 453030
    Aliexpress.com
    Michael_B - 回复
  7. Polar V800 Motherboard Replacement: 步骤 7 中的图像 1,1
    • Gently pull the wires from their solder joints to disconnect them from the body of the watch.
    • If the wires do not come off easily, you may need to desolder the connections. Visit 如何焊接和拆焊 for more help on soldering.
    • To reconnect the wires to their solder joints, they must be soldered on. See the guide linked above for more guidance.
结论
2等其他人完成本指南。
Jarod Lyles
于04/18/18注册
833 声望
创作了5篇指南
团队
Cal Poly, Team S17-G6, Livingston Spring 2018 Cal Poly, Team S17-G6, Livingston Spring 2018 的会员
CPSU-LIVINGSTON-S18S17G6
4 名成员
创作了8篇指南
2条评论
Where can the replacement motherboard be bought? Thanks
Randall - 回复
Bonjour et merci pour ses photos ezt explication, mais savez vous ou commander le joint rouge entourant et faisant l “ étanchéité de celle ci. Merci
facebook - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 16
总计 1,633
