跳转到主内容
PlayStation Move Rumble Motor Replacement
你所需要的
  1. PlayStation Move Rumble Motor Replacement, Case: 步骤 1 中的图像 1,2 PlayStation Move Rumble Motor Replacement, Case: 步骤 1 中的图像 2,2
    • Turn the controller over and unscrew the four 10mm screws with a PH #00 screwdriver.
  2. PlayStation Move Rumble Motor Replacement: 步骤 2 中的图像 1,3 PlayStation Move Rumble Motor Replacement: 步骤 2 中的图像 2,3 PlayStation Move Rumble Motor Replacement: 步骤 2 中的图像 3,3
    • Pinch the sides of the back panel to remove it and set it aside.
  3. PlayStation Move Rumble Motor Replacement: 步骤 3 中的图像 1,2 PlayStation Move Rumble Motor Replacement: 步骤 3 中的图像 2,2
    • Hold the base of the controller with one hand and with the other carefully pull up on the white spherical piece to remove it.
  4. PlayStation Move Rumble Motor Replacement: 步骤 4 中的图像 1,2 PlayStation Move Rumble Motor Replacement: 步骤 4 中的图像 2,2
    • Push the Lithium Ion battery from its slot to remove it.
    • Be mindful not to damage the wires or wired components, as the battery will still be attached via its connector.
  5. PlayStation Move Rumble Motor Replacement: 步骤 5 中的图像 1,1
    • Unscrew the 9mm screw in the battery slot with a PH #00 screwdriver.
  6. PlayStation Move Rumble Motor Replacement: 步骤 6 中的图像 1,2 PlayStation Move Rumble Motor Replacement: 步骤 6 中的图像 2,2
    • Using a plastic opening tool, carefully pry the rumble motor free.
  7. PlayStation Move Rumble Motor Replacement: 步骤 7 中的图像 1,1
    • Unscrew the 9mm screw behind the rumble motor slot with a PH #00 screwdriver.
  8. PlayStation Move Rumble Motor Replacement: 步骤 8 中的图像 1,3 PlayStation Move Rumble Motor Replacement: 步骤 8 中的图像 2,3 PlayStation Move Rumble Motor Replacement: 步骤 8 中的图像 3,3
    • Carefully pinch the plastic sides of the battery slot and lift it (along with the circuit board) from the plastic shell of the move controller.
  9. PlayStation Move Rumble Motor Replacement: 步骤 9 中的图像 1,2 PlayStation Move Rumble Motor Replacement: 步骤 9 中的图像 2,2
    • Using your fingers, carefully pry the square green piece beneath the battery slot free.
    • It is attached via white ribbons which need to be kept intact.
  10. PlayStation Move Rumble Motor Replacement: 步骤 10 中的图像 1,3 PlayStation Move Rumble Motor Replacement: 步骤 10 中的图像 2,3 PlayStation Move Rumble Motor Replacement: 步骤 10 中的图像 3,3
    • Follow the white ribbon attached to the part you just removed to a smaller, more rectangular piece.
    • Lift the rectangular piece from its slot to free it.
  11. PlayStation Move Rumble Motor Replacement: 步骤 11 中的图像 1,3 PlayStation Move Rumble Motor Replacement: 步骤 11 中的图像 2,3 PlayStation Move Rumble Motor Replacement: 步骤 11 中的图像 3,3
    • Carefully lift the entire circuit board from the black plastic encasing it.
    • Take extra care not to damage any of the wired components.
  12. PlayStation Move Rumble Motor Replacement, Rumble Motor: 步骤 12 中的图像 1,1
    • Using a soldering iron, carefully desolder the wires from the board. For help with desoldering, please check out this guide: How To Solder and Desolder Connections
    • In order to install the new rumble motor, you must solder the wires of the new motor to the circuit board.
结论
Sarah Shand
于02/20/17注册
1,912 声望
创作了7篇指南
团队
USF Tampa, Team S3-G1, Sullivan Spring 2017 USF Tampa, Team S3-G1, Sullivan Spring 2017 的会员
USFT-SULLIVAN-S17S3G1
3 名成员
创作了13篇指南
一条评论
Step 7, there are 2 screws at the top near the white spherical piece holding the PCB on place that also need to be removed before you can lift it out
Steve Massart - 回复
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 18
过去 30 天: 31
总计 1,516
