跳转到主内容
PlayStation 5 Optical Drive Laser Replacement
你所需要的
  1. PlayStation 5 Optical Drive Laser Replacement, Remove the stand screw: 步骤 1 中的图像 1,1
    • If your PlayStation 5 is in its vertical orientation, flip it upside down so the stand is facing up.
    • If your PlayStation 5 is in its horizontal orientation, skip to Step 6.
    • Work on a flat surface to prevent your PlayStation from falling over.
    • Use a coin or a flathead screwdriver to remove the 26.5 mm-long stand screw.
  2. PlayStation 5 Optical Drive Laser Replacement, Remove the vertical stand: 步骤 2 中的图像 1,2 PlayStation 5 Optical Drive Laser Replacement, Remove the vertical stand: 步骤 2 中的图像 2,2
    • Lift straight up to remove the stand.
  3. PlayStation 5 Optical Drive Laser Replacement, Store the stand screw: 步骤 3 中的图像 1,2 PlayStation 5 Optical Drive Laser Replacement, Store the stand screw: 步骤 3 中的图像 2,2
    • Insert the screw into the cubby on the bottom of the stand.
  4. PlayStation 5 Optical Drive Laser Replacement, Cap the screw hole: 步骤 4 中的图像 1,3 PlayStation 5 Optical Drive Laser Replacement, Cap the screw hole: 步骤 4 中的图像 2,3 PlayStation 5 Optical Drive Laser Replacement, Cap the screw hole: 步骤 4 中的图像 3,3
    在这个步骤中使用的工具:
    • Use a pair of tweezers or your fingernail to remove the cap from the cubby.
    • Use your finger to press the cap into the screw hole.
  5. PlayStation 5 Optical Drive Laser Replacement, Close the cubby: 步骤 5 中的图像 1,3 PlayStation 5 Optical Drive Laser Replacement, Close the cubby: 步骤 5 中的图像 2,3 PlayStation 5 Optical Drive Laser Replacement, Close the cubby: 步骤 5 中的图像 3,3
    • Twist the stand counterclockwise to close the cubby.
  6. PlayStation 5 Optical Drive Laser Replacement, Remove the horizontal stand: 步骤 6 中的图像 1,2 PlayStation 5 Optical Drive Laser Replacement, Remove the horizontal stand: 步骤 6 中的图像 2,2
    • If your PlayStation 5 is in its horizontal orientation, rest it on its face with the charging port facing up.
    • Lift the stand straight up to remove it.
  7. PlayStation 5 Optical Drive Laser Replacement, Remove the right faceplate: 步骤 7 中的图像 1,3 PlayStation 5 Optical Drive Laser Replacement, Remove the right faceplate: 步骤 7 中的图像 2,3 PlayStation 5 Optical Drive Laser Replacement, Remove the right faceplate: 步骤 7 中的图像 3,3
    • Flip the device over so that the USB and ethernet ports are on the left side from your perspective.
    • Lift up the corner of the faceplate to unclip it from the case.
  8. PlayStation 5 Optical Drive Laser Replacement: 步骤 8 中的图像 1,2 PlayStation 5 Optical Drive Laser Replacement: 步骤 8 中的图像 2,2
    • While lifting up the corner, slide the faceplate towards the bottom of the device.
    • Remove the right faceplate.
  9. PlayStation 5 Optical Drive Laser Replacement, Pry up the grille: 步骤 9 中的图像 1,3 PlayStation 5 Optical Drive Laser Replacement, Pry up the grille: 步骤 9 中的图像 2,3 PlayStation 5 Optical Drive Laser Replacement, Pry up the grille: 步骤 9 中的图像 3,3
    • Insert the flat end of a spudger underneath the grille and into the gap above the fan.
    • Lift up with the spudger to pry the grille away from the case.
  10. PlayStation 5 Optical Drive Laser Replacement, Remove the grille: 步骤 10 中的图像 1,2 PlayStation 5 Optical Drive Laser Replacement, Remove the grille: 步骤 10 中的图像 2,2
    • Lift the grille away from the case to remove it.
  11. PlayStation 5 Optical Drive Laser Replacement, Remove the fan shroud screws: 步骤 11 中的图像 1,1
    在这个步骤中使用的工具:
    Magnetic Project Mat
    $16.96
    • Use a T9 Torx Security driver to remove the four screws securing the fan shroud to the case:
    • Two 23.3 mm-long screws
    • One 11.4 mm-long screw
    • One 31 mm-long screw
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your console.
  12. PlayStation 5 Optical Drive Laser Replacement, Remove the fan shroud: 步骤 12 中的图像 1,2 PlayStation 5 Optical Drive Laser Replacement, Remove the fan shroud: 步骤 12 中的图像 2,2
    • Lift the fan shroud straight up to remove it.
  13. PlayStation 5 Optical Drive Laser Replacement, Remove the wire cover: 步骤 13 中的图像 1,3 PlayStation 5 Optical Drive Laser Replacement, Remove the wire cover: 步骤 13 中的图像 2,3 PlayStation 5 Optical Drive Laser Replacement, Remove the wire cover: 步骤 13 中的图像 3,3
    • Insert the flat end of a spudger beneath the black wire cover and into the gap above the fan wires.
    • Pry only on the wire cover, not on the fan wires themselves.
    • Use the spudger to peel up the wire cover until you can grip it with your fingers.
  14. PlayStation 5 Optical Drive Laser Replacement: 步骤 14 中的图像 1,3 PlayStation 5 Optical Drive Laser Replacement: 步骤 14 中的图像 2,3 PlayStation 5 Optical Drive Laser Replacement: 步骤 14 中的图像 3,3
    • Use your fingers to peel off the wire cover.
  15. PlayStation 5 Optical Drive Laser Replacement, Disconnect the fan: 步骤 15 中的图像 1,2 PlayStation 5 Optical Drive Laser Replacement, Disconnect the fan: 步骤 15 中的图像 2,2
    • Use your fingers to grip the edges of the fan cable connector, and pull up to disconnect it from the motherboard.
    • Always pull cables by their connectors and not the wires themselves.
  16. PlayStation 5 Optical Drive Laser Replacement, Remove the fan: 步骤 16 中的图像 1,3 PlayStation 5 Optical Drive Laser Replacement, Remove the fan: 步骤 16 中的图像 2,3 PlayStation 5 Optical Drive Laser Replacement, Remove the fan: 步骤 16 中的图像 3,3
    • Lift the fan up and out of the case to remove it.
  17. PlayStation 5 Optical Drive Laser Replacement, Remove the SSD cover: 步骤 17 中的图像 1,1
    • Use a Phillips screwdriver to remove the 17 mm-long SSD cover screw.
  18. PlayStation 5 Optical Drive Laser Replacement: 步骤 18 中的图像 1,3 PlayStation 5 Optical Drive Laser Replacement: 步骤 18 中的图像 2,3 PlayStation 5 Optical Drive Laser Replacement: 步骤 18 中的图像 3,3
    • Use your finger to slide the SSD cover towards the top of the device to unclip it from the case.
    • Remove the SSD cover.
  19. PlayStation 5 Optical Drive Laser Replacement, Remove the optical drive wire: 步骤 19 中的图像 1,2 PlayStation 5 Optical Drive Laser Replacement, Remove the optical drive wire: 步骤 19 中的图像 2,2
    • Use your fingers to grip the edges of the optical drive cable connector, and pull up to disconnect it from the motherboard.
  20. PlayStation 5 Optical Drive Laser Replacement: 步骤 20 中的图像 1,2 PlayStation 5 Optical Drive Laser Replacement: 步骤 20 中的图像 2,2
    • Use your fingers to grip the edges of the optical drive cable connector, and pull up to disconnect it from the optical drive.
  21. PlayStation 5 Optical Drive Laser Replacement, Remove the tamper-evident sticker: 步骤 21 中的图像 1,3 PlayStation 5 Optical Drive Laser Replacement, Remove the tamper-evident sticker: 步骤 21 中的图像 2,3 PlayStation 5 Optical Drive Laser Replacement, Remove the tamper-evident sticker: 步骤 21 中的图像 3,3
    在这个步骤中使用的工具:
    • Use a pair of tweezers to remove the tamper-evident sticker covering the remaining case screw.
    • If your PlayStation 5 hasn't been opened before, this sticker will be completely black. The pattern will appear after you remove it.
    • Technically, these are tamper-evident stickers—but don't worry—Sony can't legally void your warranty, as long as you don't damage anything. Have fun!
  22. PlayStation 5 Optical Drive Laser Replacement, Remove the case screws: 步骤 22 中的图像 1,1
    • Use a T8 Torx driver to remove the eleven screws securing the case:
    • Six 18.6 mm-long screws
    • Two 43.2 mm-long screws
    • One 7.3 mm-long screw
  23. PlayStation 5 Optical Drive Laser Replacement, Remove the case: 步骤 23 中的图像 1,2 PlayStation 5 Optical Drive Laser Replacement, Remove the case: 步骤 23 中的图像 2,2
    • Lift the case straight up to remove it.
  24. PlayStation 5 Optical Drive Laser Replacement, Remove the optical drive ribbon cable: 步骤 24 中的图像 1,3 PlayStation 5 Optical Drive Laser Replacement, Remove the optical drive ribbon cable: 步骤 24 中的图像 2,3 PlayStation 5 Optical Drive Laser Replacement, Remove the optical drive ribbon cable: 步骤 24 中的图像 3,3
    • Use the flat end of a spudger to press down on the optical drive connector's metal locking tab.
    • With the metal tab depressed, use a pair of tweezers to pull the blue pull tab directly away from the connector to disconnect the cable from the optical drive.
    • Pull only on the pull tab, not the cable itself.
  25. PlayStation 5 Optical Drive Laser Replacement, Remove the optical drive: 步骤 25 中的图像 1,2 PlayStation 5 Optical Drive Laser Replacement, Remove the optical drive: 步骤 25 中的图像 2,2
    • Lift the optical drive away from the device to remove it.
  26. PlayStation 5 Optical Drive Laser Replacement, Remove screws from top cover: 步骤 26 中的图像 1,1
    • silver screws: 4x M1.6 X 3.7mm, with 6.5mm head.
    • black screws: 9x M1.6 x 3.8mm.
    • Remove screws with Phillips #1 screwdriver.
  27. PlayStation 5 Optical Drive Laser Replacement, Remove top cover: 步骤 27 中的图像 1,2 PlayStation 5 Optical Drive Laser Replacement, Remove top cover: 步骤 27 中的图像 2,2
    • Lift off the top cover.
  28. PlayStation 5 Optical Drive Laser Replacement, disconnect FFC cables and 2 wire lead: 步骤 28 中的图像 1,3 PlayStation 5 Optical Drive Laser Replacement, disconnect FFC cables and 2 wire lead: 步骤 28 中的图像 2,3 PlayStation 5 Optical Drive Laser Replacement, disconnect FFC cables and 2 wire lead: 步骤 28 中的图像 3,3
    在这个步骤中使用的工具:
    • Gently pull the medium and narrow FFC flexes and the 2-wire lead from their sockets. Suitable tweezers (bent with points or straight blunt end) can be used to aid removal.
  29. PlayStation 5 Optical Drive Laser Replacement, Remove screws from the PCB.: 步骤 29 中的图像 1,2 PlayStation 5 Optical Drive Laser Replacement, Remove screws from the PCB.: 步骤 29 中的图像 2,2
    • black screws: 2x M1.6 x 3.8mm
  30. PlayStation 5 Optical Drive Laser Replacement, Remove base plate: 步骤 30 中的图像 1,1
    • Lift off the PCB and attached assembly from the metal plate.
  31. PlayStation 5 Optical Drive Laser Replacement, Flip over: 步骤 31 中的图像 1,1
    • Turn over the PCB and attached assembly.
  32. PlayStation 5 Optical Drive Laser Replacement, Disconnect FFC cable and remove the PCB.: 步骤 32 中的图像 1,2 PlayStation 5 Optical Drive Laser Replacement, Disconnect FFC cable and remove the PCB.: 步骤 32 中的图像 2,2
    • Unlatch the wide FFC socket.
    • Gently remove the wide FFC cable from the socket and set aside the PCB.
  33. PlayStation 5 Optical Drive Laser Replacement, flip over the assembly: 步骤 33 中的图像 1,1
    • Flip over the assembly.
  34. PlayStation 5 Optical Drive Laser Replacement, Remove the screws from mechanism plate: 步骤 34 中的图像 1,2 PlayStation 5 Optical Drive Laser Replacement, Remove the screws from mechanism plate: 步骤 34 中的图像 2,2
    • Use a Phillips #1 screwdriver to remove the screws.
    • black screws: 4x M1.6 x 3.8mm.
  35. PlayStation 5 Optical Drive Laser Replacement, Remove the mechanism plate: 步骤 35 中的图像 1,3 PlayStation 5 Optical Drive Laser Replacement, Remove the mechanism plate: 步骤 35 中的图像 2,3 PlayStation 5 Optical Drive Laser Replacement, Remove the mechanism plate: 步骤 35 中的图像 3,3
    • Remove the mechanism plate and set aside.
  36. PlayStation 5 Optical Drive Laser Replacement, Remove the FFC cable from laser deck: 步骤 36 中的图像 1,3 PlayStation 5 Optical Drive Laser Replacement, Remove the FFC cable from laser deck: 步骤 36 中的图像 2,3 PlayStation 5 Optical Drive Laser Replacement, Remove the FFC cable from laser deck: 步骤 36 中的图像 3,3
    • Push down on the roller mech and remove the FFC cable from laser deck (near roller mech).
    • Blunt end straight tweezers can be used to aide removal of the FFC flex. To remove the flex from the socket, pull the flex towards the rollers.
  37. PlayStation 5 Optical Drive Laser Replacement, Remove the screws holding the laser deck: 步骤 37 中的图像 1,2 PlayStation 5 Optical Drive Laser Replacement, Remove the screws holding the laser deck: 步骤 37 中的图像 2,2
    • Remove the screws using a Phillips #1 screw driver.
    • silver screws: 4x M1.6 X 3.7mm 6.5mm head
  38. PlayStation 5 Optical Drive Laser Replacement, Remove the laser deck: 步骤 38 中的图像 1,2 PlayStation 5 Optical Drive Laser Replacement, Remove the laser deck: 步骤 38 中的图像 2,2
    • Remove the laser deck.
  39. PlayStation 5 Optical Drive Laser Replacement, Remove the screws from metal plate over laser motor: 步骤 39 中的图像 1,2 PlayStation 5 Optical Drive Laser Replacement, Remove the screws from metal plate over laser motor: 步骤 39 中的图像 2,2
    • Remove the screws from metal plate over laser motor.
    • Use a Phillips PH0 screwdriver to remove the screws.
    • silver screws: 2x M1.7 X 3.8mm
  40. PlayStation 5 Optical Drive Laser Replacement, Remove the metal plate over the laser motor: 步骤 40 中的图像 1,2 PlayStation 5 Optical Drive Laser Replacement, Remove the metal plate over the laser motor: 步骤 40 中的图像 2,2
    • Remove the metal plate covering the laser motor.
  41. PlayStation 5 Optical Drive Laser Replacement, Remove the screws holding the laser motor to the drive deck: 步骤 41 中的图像 1,2 PlayStation 5 Optical Drive Laser Replacement, Remove the screws holding the laser motor to the drive deck: 步骤 41 中的图像 2,2
    • Remove the screws holding the laser motor to the drive deck.
  42. PlayStation 5 Optical Drive Laser Replacement, Flip over and remove the screw from the white plastic bracket.: 步骤 42 中的图像 1,3 PlayStation 5 Optical Drive Laser Replacement, Flip over and remove the screw from the white plastic bracket.: 步骤 42 中的图像 2,3 PlayStation 5 Optical Drive Laser Replacement, Flip over and remove the screw from the white plastic bracket.: 步骤 42 中的图像 3,3
    • flip over and remove a single black screw from white plastic bracket.
    • Note: laser motor will be loose, so be careful when you flip over the deck for the next step.
    • Remove the screw with a Phillips PH0 screwdriver.
    • black screw: 1x M1.4 x 3.9mm
    • Remove the white bracket and set aside.
  43. PlayStation 5 Optical Drive Laser Replacement, Flip over the laser deck and move the laser motor to the side: 步骤 43 中的图像 1,2 PlayStation 5 Optical Drive Laser Replacement, Flip over the laser deck and move the laser motor to the side: 步骤 43 中的图像 2,2
    • Flip over the laser deck and move the laser motor to the side
  44. PlayStation 5 Optical Drive Laser Replacement, Remove the rod retention clip.: 步骤 44 中的图像 1,3 PlayStation 5 Optical Drive Laser Replacement, Remove the rod retention clip.: 步骤 44 中的图像 2,3 PlayStation 5 Optical Drive Laser Replacement, Remove the rod retention clip.: 步骤 44 中的图像 3,3
    • remove the clip that stops the rod from being removed.
    • a) Use a 1.5mm slotted screwdriver to push the lower end of the clip to the left, to unhook it from the retaining hook.
    • b) The clip should pop up.
    • c) lift out the clip.
  45. PlayStation 5 Optical Drive Laser Replacement, Slide out the rod from the laser module.: 步骤 45 中的图像 1,3 PlayStation 5 Optical Drive Laser Replacement, Slide out the rod from the laser module.: 步骤 45 中的图像 2,3 PlayStation 5 Optical Drive Laser Replacement, Slide out the rod from the laser module.: 步骤 45 中的图像 3,3
    • slide out the rod from the laser module.
  46. PlayStation 5 Optical Drive Laser Replacement, Remove the laser module: 步骤 46 中的图像 1,2 PlayStation 5 Optical Drive Laser Replacement, Remove the laser module: 步骤 46 中的图像 2,2
    • Remove the laser module
  47. PlayStation 5 Optical Drive Laser Replacement, Flip over the laser module: 步骤 47 中的图像 1,2 PlayStation 5 Optical Drive Laser Replacement, Flip over the laser module: 步骤 47 中的图像 2,2
    • Flip over the laser module.
  48. PlayStation 5 Optical Drive Laser Replacement, unlatch the FFC connector and remove the FFC flex from the laser.: 步骤 48 中的图像 1,2 PlayStation 5 Optical Drive Laser Replacement, unlatch the FFC connector and remove the FFC flex from the laser.: 步骤 48 中的图像 2,2
    • unlatch the FFC connector.
    • Remove the FFC flex from the laser.
结论
Repair didn’t go as planned? Try some basic troubleshooting, or ask our PlayStation 5 Answers community for help.
16等其他人完成本指南。
David Fear
于06/10/17注册
408 声望
撰写一个指南
4指南评论
Danke für die tolle und ausführliche Anleitung!
Discs werden wieder gelesen *freu*
Jan Bäumler - 回复
where do we get the replacement laser?
canegosh - 回复
Muchísimas gracias por la guía, me ha resultado imprescindible para hacer el cambio con éxito!
Pepe Paco - 回复
whats the name of the ribbon data cable that goes from this drive to the ps. The one taken off at the start before tearing down the bluray playe. Thanks
L2D2 - 回复
添加评论
浏览统计数据:
过去 24 小时: 48
过去 7 天: 379
过去 30 天: 1,720
总计 40,755
