简介
这是一个超级简单的修复教程,我觉得大部分人都有能力成功完成它。
当然了,使用本指南,将默认您承担一切后果,本文作者TronicsFix对此不负任何责任并且不保证任何可能的毁坏。
你所需要的
把PS4接上电源线缆。
触摸PS4的金属板,令其开机。[1]
[1]: 译者注:此步可能会有危险,建议使用导线接地而非直接触摸。
如果PS4开机并正常运行,说明问题已经修复;如果没有请继续看下一步。
在您已经按照教程操作之后,如果您的PS4还是开不了机(或者开机瞬关),尝试去盖好盖子并且拧紧金属板上的螺丝。如果螺丝过紧,PS4就会拒绝工作。略微拧松一些,知道系统可以正常启动。在接上电源以后请小心操作。这样可能成功但是并不推荐。[2]
[2]: 译者注:去维修店吧,再搞怕是要出事。
想要重装回您的设备,按这些步骤的相反顺序重新操作即可。
56等其他人完成本指南。
由衷感谢以下译者:
100%
这些译者帮助我们修补全世界! 您也想加入吗?
开始翻译 ›
49条评论
Can't believe it worked! My PS4 has been sitting useless for so long and I felt to good when I did this today and it seemed completely normal again. We'll see if this works out over time or if it starts doing the same thing again. One thing I don't get is why they don't specify the washer size you'll need if you don't want to buy the entire kit, but I guess that's just marketing. Thus, I tore squares of glossy paper (a picture I had laying around) and poked them into the nails instead of washers. Works just as well for me!
What size washers are needed for this
has this fixed your system permanently? did you have any problems since your last post?
worked for me!
and it will for a few day/weeks at most then it will fail again
